We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Draytek VigorSwitch P2280X - Switch - Managed - 24 x 10/100/1000 (PoE+) + 4 x 10Gb Ethernet SFP+ - desktop, rack-mountable - PoE+ (400 W)
Product Description | Draytek VigorSwitch P2280X - switch - 28 ports - Managed - rack-mountable | Device Type | Switch - 28 ports - Managed | Enclosure Type | Rack-mountable 1U | Subtype | Gigabit Ethernet | Ports | 24 x 10/100/1000 (PoE+) + 4 x 10Gb Ethernet SFP+ | Power Over Ethernet (PoE) | PoE+ | PoE Budget | 400 W | Performance | Switching capacity: 128 Gbps , Forwarding rate: 95.24 Mpps , Packet buffer size: 12 Mbit | Capacity | Link aggregation groups: 8 , ACL entries: 512 , VLANs supported: 255 , VLAN IDs: 4096 | MAC Address Table Size | 16K entries | Jumbo Frame Support | 12KB | Routing Protocol | VRRP, MSTP, RSTP, STP | Remote Management Protocol | SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, CLI, ICMP | Features | Load balancing, VLAN support, DoS attack prevention, IPv6 support, SNTP support, sFlow, Virtual Route Redundancy Protocol (VRRP) support, event log, DHCP snooping, Quality of Service (QoS), Dynamic ARP Inspection (DAI), IPv4 support, LACP support, DHCP relay, DHCP client, Dynamic VLAN Support (GVRP), dual firmware images, Strict Priority Queuing (SPQ), Neighbor Discovery Protocol (NDP), loop prevention, port isolation, static routing, Virtual Stacking Management (VSM), Class of Service (CoS), ONVIF support, Duplicated Address Detection, Type of Service (ToS), DiffServ Code Point (DSCP) support, PoE circuit sorting protection, Storm Control, system log, IP source guard, rate limit, MAC address authentication, Authentication, Authorization and Accounting (AAA), DNS client, Voice VLAN, VLAN management, Guest VLAN, ingress rate limiting, Weighted Round Robin (WRR), MAC based VLAN, egress rate limiting, OpenVPN client | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ad, IEEE 802.1v, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az | Power | AC 120/230 V | Dimensions (WxDxH) | 44.1 cm x 27 cm x 4.5 cm | Weight | 4.32 kg | Manufacturer Warranty | 2-year warranty |
General | |
Enclosure Type | Desktop, rack-mountable 1U |
Authentication Method | Secure Shell (SSH), RADIUS, TACACS+ |
Status Indicators | Port transmission speed, power, alert, system, PoE, link/activity |
Expansion / Connectivity | |
Interfaces | 24 x 1000Base-T RJ-45 PoE+ - 30 W , 4 x Gigabit / 10Gbit LAN SFP , 1 x console RJ-45 |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V |
Power Consumption Operational | 480 Watt |
Miscellaneous | |
Rack Mounting Kit | Included |
Compliant Standards | RoHS |
Dimensions & Weight | |
Width | 44.1 cm |
Depth | 27 cm |
Height | 4.5 cm |
Weight | 4.32 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 70 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
