Marketing description is not available.
Product Description | Draytek VigorSwitch G2280X - switch - 28 ports - Managed - rack-mountable | Device Type | Switch - 28 ports - L2+ - Managed | Enclosure Type | Rack-mountable 1U | Subtype | 10 Gigabit Ethernet | Ports | 24 x 10/100/1000 + 4 x 10 Gigabit SFP+ (uplink) | Performance | Switching capacity: 128 Gbps , Buffer memory: 12 Mbit , Forwarding rate: 95.24 Mpps | Capacity | Multicast groups: 256 , Total link aggregation groups: 8 | MAC Address Table Size | 16K entries | Jumbo Frame Support | 12KB | Routing Protocol | IGMPv2, IGMPv3, MLDv2, MLD | Remote Management Protocol | SNMP 1, RMON, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, CLI | Features | Flow control, auto-negotiation, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), DHCP server, MLD snooping, IPv4 support, LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), DHCP client, Multicast VLAN Registration (MVR), loop prevention, port isolation, Class of Service (CoS), Strict Priority (SP), IP source guard, Link Aggregation, Voice VLAN, protected ports, Energy-Efficient Ethernet (EEE), Weighted Round Robin (WRR), DSCP based CoS, Q-in-Q tunnelling | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az | Power | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 44.1 cm x 27 cm x 4.5 cm | Weight | 2.48 kg | Localisation | United Kingdom | Manufacturer Warranty | 2-year warranty |
General | |
Authentication Method | RADIUS, TACACS+, internal user database |
Expansion / Connectivity | |
Interfaces | 24 x 1000Base-T RJ-45 , 4 x 10Gbit LAN SFP+ uplink , 1 x console RJ-45 management |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 25 Watt |
Miscellaneous | |
Cables Included | 1 x console cable |
Rack Mounting Kit | Included |
Compliant Standards | RoHS |
Dimensions & Weight | |
Width | 44.1 cm |
Depth | 27 cm |
Height | 4.5 cm |
Weight | 2.48 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 70 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
