Dynabook Portege A30-E-14P Intel Core i7-8550U 8GB 256GB SSD...
Dynabook Portege A30-E-14P Intel Core i7-8550U 8GB 256GB SSD 13" Windows 10 Professional 64-bit
£1,114.23
Delivery:
Key features
  • Windows 10 Pro 64-bit – Dynabook recommends Windows 10 Pro for business
  • 8th generation Intel Core i7-8550U processor
  • 33.8cm (13.3"), Non-reflective Full HD display 470 nit
  • Solid State Drive M.2 PCIe 256 GB
  • Black with precious hairline
  • 8,192 (onboard) MB, DDR4 RAM (2400MHz)
  • Intel UHD Graphics 620
  • Maximum life: up to 8h45min (MobileMark 2014 running Windows 10)
  • MobileMark is a trademark of Business Applications Performance Corporation
  • Weight: starting at 1.20 kg
  • W x L x H: 316 × 227 × 19.9 mm
Product codes
The freedom to perform
Designed, engineered and manufactured in-house to dynabook’s rigorous quality standards, the Portégé A30-E delivers unrivalled productivity and reliability on the move, with portable convenience to create and collaborate. A powerful, long-lasting battery, high-brightness no-glare screen and optional LTE, which means there is freedom to work effectively anywhere.
No limitations
Durability, reliability and strength are at the heart of the Portégé A30-E. Tested to MIL-STD-810 military standards and ready for any situation that the working day can throw at it, this laptop is built to last. Expect endurance, a long lifecycle and a healthy ROI.
Safe and secure, always
Business security is taken care of with the Portégé A30-E. Built-in data protection includes unique in-house BIOS for maximum security, plus TPM, biometric login and a wide range of optional authentication features to ensure your data doesn’t fall into the wrong hands. Optional smartcard, two-factor authentication, including IR-based Windows Hello and inbuilt fingerprint reader, and even a special slimline lock to keep the device physically secure all guarantee peace of mind.
Fast, reliable connectivity
dynabook’s Portégé A30-E has an extensive range of connectivity options, from a Gigabit-LAN port to Intel® Dual Band Wireless-AC 8265 2X2 WIFI Antenna and everything in between. This guarantees fast, reliable network connections in the office, at home or on the go, allowing collaboration and creativity to flow everywhere. USB Type-C ensures a multitude of connections to charge, connect to a display or transfer data, or do all three at once.
Engineered to excel
The Portégé A30-E has been designed and engineered in-house to deliver maximum processing power in an ultra-thin and light form factor. With an 8th generation CPU and SSD hard drive, this device is built to run even the most demanding programs and multitask efficiently with DDR4 RAM that’s expandable to 24 GB. Unrivalled productivity and reliability provide the power to conquer every challenge of the working day.
Product Description Dynabook Toshiba Portégé A30-E-14P - 13.3" - Core i7 8550U - 8 GB RAM - 256 GB SSD
Product Type Notebook
Operating System Win 10 Pro 64-bit
Processor Intel Core i7 (8th Gen) 8550U / 1.8 GHz (4 GHz) / 8 MB Cache
Memory 8 GB DDR4 (8 GB (soldered))
Storage 256 GB SSD
Optical Drive No optical drive
Display 13.3" 1920 x 1080 / Full HD
Graphics Intel UHD Graphics 620
Input Device SecurePad
Keyboard Backlight Yes
Integrated Webcam Yes
Networking 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
Battery 4-cell - up to 8.75 hours
Security Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
Colour Tile black (keyboard), black with precious hairline
Dimensions (WxDxH) 31.6 cm x 22.7 cm x 1.99 cm
Weight 1.2 kg
Localisation Region: United Kingdom
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty EMEA warranty - 1 year - carry-in
Bundled Services 1 Year Reliability Guarantee
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Dynabook Portege A30-E...
£1,114.23
