Dynabook Portege X40-E-11M Intel Core i5-8250U 8GB 256GB SSD...
Dynabook Portege X40-E-11M Intel Core i5-8250U 8GB 256GB SSD 14" Windows 10 Professional 64-bit
£1,112.00
Delivery:
Key features
  • Windows 10 Pro 64-bit – Dynabook recommends Windows 10 Pro for business
  • 8th generation Intel Core i5-8250U processor
  • 35.6cm (14.0"), Non-reflective Full HD display with In-Cell Touch
  • Solid State Drive M.2 PCIe 256 GB
  • Onyx Blue with Hair line
  • 8,192 MB, DDR4 RAM (2400MHz)
  • Intel UHD Graphics 620
  • Maximum life: up to 11h15min (MobileMark 2014 running Windows 10)
  • MobileMark is a trademark of Business Applications Performance Corporation
  • Weight: starting at 1.25 kg
  • W x L x H: 332 x 228.9 x 16.9 mm
Product codes
Power through your working day with business-grade performance, confident that the thin, light design of the Tecra X40-E is up to the day-to-day pressures of your workload, thanks to extensive testing.
From the factory to the office, the Tecra X40-E is secure at every step. Two-factor authentication includes IR-based Windows Hello and a built-in SecurePad with fingerprint reader. And the X40-E includes a slimline security lock slot and magnesium chassis with honeycomb design for physical strength and security.
The Tecra X40-E comes with Toshiba's Hybrid Air Cooling System, which uses two air inlets to maintain an optimum device temperature - without compromising performance. The Tecra X40-E is all you need to keep your productivity up and your laptop's temperature down.
The Tecra X40-E is designed to be easy and enjoyable to use. In-Cell touch technology lets you work your way - by touch with your fingers and without compromising on the exceptional clarity of the non-glare screen.
The Tecra X40-E has been designed to be the compact and mobile powerhouse that ticks every box for business users. Twin Thunderbolt 3 ports enable you to work your way - wherever you are.
Product Description Dynabook Toshiba Tecra X40-E-11M - 14" - Core i5 8250U - 8 GB RAM - 256 GB SSD
Product Type Notebook
Operating System Win 10 Pro 64-bit
Processor Intel Core i5 (8th Gen) 8250U / 1.6 GHz (3.4 GHz) / 6 MB Cache
Memory 8 GB DDR4
Storage 256 GB SSD
Optical Drive No optical drive
Display 14" touchscreen 1920 x 1080 / Full HD
Graphics Intel UHD Graphics 620
Input Device AccuPoint, SecurePad
Keyboard Backlight Yes
Integrated Webcam Yes
Networking 802.11a/b/g/n/ac, Bluetooth 4.2
Battery 3-cell - up to 11.25 hours
Security Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
Colour Matte black (keyboard), onyx blue with hairline
Dimensions (WxDxH) 33.2 cm x 22.89 cm x 1.69 cm
Weight 1.25 kg
Localisation Region: United Kingdom, Ireland
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty EMEA warranty - 1 year - carry-in
Bundled Services 1 Year Reliability Guarantee
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Dynabook Portege X40-E...
£1,112.00
