EE 4GEE Router
EE 4GEE Router
£129.99
Delivery:
Standard: 1-3 working days
Express: Delivered on Tuesday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Superfast speeds
  • No need for a landline
  • Set-up in seconds
  • 30m Wi-Fi range
  • Connect up to 32 devices
  • LAN port
  • Type: Wireless router
  • Standards: IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g + 1 more
  • Stock Status: In Stock
Product codes
The ideal alternative to slow home broadband
Are you struggling with slow home broadband speeds in your area? Maybe you’re having trouble getting fixed broadband installed or staying somewhere temporarily. Our 4GEE Home router could be the answer.
Delivered through 4GEE on the UK’s fastest network, you can get average speeds of 31Mb/s in some places, that’s faster than standard fibre broadband.
Superfast speeds
If you live in a slow speed area, our 4GEE Home Router can give you faster speeds over the 4G network.
There’s no wait to get a landline installed, so you can start using your 4GEE Home router instantly.
Set-up in seconds
There’s no engineer visit or wait to get installed. Just plug in the power to get connected instantly.
30m WiFi range
With its increased range, your WiFi signal is distributed effectively all
With the ability to connect up to 32 devices, you can keep the whole home connected on multiple devices.
LAN Port
4GEE Home router includes a Local Area Network port for improved connectivity
Product Description 4GEE Home Router - wireless router - WWAN - 802.11a/b/g/n/ac - desktop
Device Type Wireless router - wireless cellular modem
Enclosure Type Desktop
Cellular Protocol LTE
Data Link Protocol IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band 2.4 GHz / 5 GHz
Features Firewall protection, MAC address filtering, reset button
Compliant Standards IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Colour White
Dimensions (WxDxH) 14.6 cm x 14.6 cm x 3.2 cm
Weight 350 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
EE 4GEE Router
£129.99
