Elgato Eve Door & Window Sensor - wireless - Bluetooth 4....
Elgato Eve Door & Window Sensor - wireless - Bluetooth 4.0 LE
£34.98
Delivery:
Key features
  • Improve your comfort
  • Gain insights
  • Easy setup
  • Use your voice
  • Advanced security
  • Simply elegant
Product codes
eve door & window - Wireless Contact Sensor
Improve your comfort.
Live smarter by knowing more about the place you care about most. With Eve Door & Window, Eve understands whether your door or window is open or closed.
Be informed.
See your home at a glance, and view beautiful graphs by day, month or year. Receive notifications about the status of your access points and know when your door or window has been opened. And with Apple TV at home, be alerted while you’re at work or on vacation.
Set Scenes
Automatically control other HomeKit-enabled accessories when you open or close a door or window. Create rules that automate your home, like setting the "I’m Home" scene when your door is opened after 6:00 p.m.
HomeKit-enabled.
Easy Setup - Eve connects directly to your iPhone or iPad using Bluetooth low energy technology, without requiring a hub, gateway or bridge.
Remote Access - You don’t even have to be home to monitor Eve. All you need is an Apple TV, and you’re ready to remotely check the status of your home at a glance.
Advanced Security - HomeKit technology provides advanced security with end-to-end encryption and authentication between Eve and your iPhone, iPad, or iPod touch.
Simply elegant.
The Eve family has been carefully designed to seamlessly blend into your home environment. This elegance extends to truly wireless operation: thanks to Bluetooth Smart technology, Eve is powered by long-lasting, replaceable batteries, so you don't even have to deal with power cords.
Eve Door & Window - door and window sensor
Door and window sensor
Power Source
Wireless - Bluetooth 4.0 LE
Supported Host Device OS
iOS
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Elgato Eve Door & Wind...
£34.98
