Elgato Eve Motion Sensor - wireless - Bluetooth
Key features
  • Ultimate versatility
  • Rule your home
  • Easy setup
  • Robust automation
  • Advanced security
  • Simply elegant
Product codes
eve motion Wireless Motion Sensor
Improve your comfort.
Let your presence bring your home to life. With Eve Motion, cue the perfect ambience simply by entering your room, and know of activity as it’s happening.
Be informed.
Receive notifications on your iPhone or iPad whenever movement is detected. Be alerted when someone enters your private space. And with Apple TV at home, keep tabs on your abode while you’re on the go.
Rule your home.
Create powerful rules with conditions to control your HomeKit-enabled accessories. Automatically activate your "I’m home" scene when you or a family member roll up the driveway, but only after sunset. Or activate a fan when you enter your living room, but only if your climate sensor has registered a certain temperature. With Eve Motion, make your accessories work in harmony with your lifestyle.
Ultimate versatility.
Eve Motion covers virtually any space thanks to a passive infrared sensor with a wide 120-degree field of view, and lengthy reach of up to 9 m / 30 ft. And, while adjustable sensitivity permits quick fine-tuning for personalized performance, IPX 3 water resistance warrants practical use outdoors.
HomeKit-enabled.
Easy Setup - Eve Motion connects directly to your iPhone, iPad, or iPod touch using Bluetooth low energy technology, without the need for a hub, gateway, bridge, or complicated WiFi configuration.
Robust Automation - With Apple TV at home, Eve Motion detects presence and prompts your HomeKit-enabled accessories even while you’re away.
Advanced Security - HomeKit technology ensures that all communication between Eve Motion and your iPhone is completely encrypted, so you can rest assured that your personal data is secure.
Simply elegant.
Eve Motion has been carefully designed to seamlessly blend into your home environment. Long-lasting, replaceable batteries eliminate the need for cumbersome power cords, while Bluetooth low energy technology makes setup a breeze, and ensures reliable operation without exhausting your already crowded WiFi setup.
Requirements
Eve requires an iPhone, iPad, or iPod touch with iOS 10.3 or later. To control this HomeKit-enabled accessory, iOS 10 or later is recommended. Controlling this HomeKit-enabled accessory automatically and away from home requires an Apple TV with tvOS 10 or later or an iPad with iOS 10 or later set up as a home hub.
Operating Range:
Field of view: 120°
Distance: 9 m / 30 ft. max at 2 m / 6.5 ft. mounting height
Operating temperature: -18°C to +55°C (: 0°F - 130°F)
IPX 3 Certified
Reaction time: two seconds
Power - 2 x AA Replaceable Batteries
Wireless Connection - Bluetooth Low Energy
Dimensions - 80 x 80 x 32 mm
Eve Motion - motion sensor
Motion sensor
Power Source
Wireless - Bluetooth
Supported Host Device OS
iOS
8 cm x 3.2 cm x 8 cm
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Elgato Eve Motion Sens...
