Energenie Mi Home Heating Starter Pack
Key features
  • Control radiators to regulate heating in the room
  • Set different temperatures in different rooms, using zonal heating
  • Save money and energy, using zonal heating
  • Using timers to set certain temperatures at certain times during the day
  • Compatible with IFTTT
Product codes
This is the Mi|Home heating bundle, consisting of radiator valves and gateway. Each eTRV controls a radiator valve to regulate the heating in the room, based on timed programs, set temperatures. Using the eTRV improves your comfort and saves energy. The benefit of having eTRVs is that it enables you to control each radiator or room individually, rather than heating your whole house from a single thermostat. Therefore you only heat the bedroom, when it is in use, which is likely to be at a different time to the lounge or sitting room. By only heating the rooms you are in you can make significant savings. The radiator valves can be used with other features, such as programs. This means, you are able to set the required radiator valve to a specific temperature and at specific time on your settings in the app.
Energenie Mi|Home Heating Pack - home automation kit
Home automation kit
Functions
Control heating systems
Internet of Things (IoT) Platform
OpenThings
Package Content
Gateway, radiator thermostat
Wireless
Frequency Band
434.3 MHz
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Energenie Mi Home Heat...
