Energenie Mi Home Radiator Valve Single Bulk
Key features
  • Control radiators to regulate heating in the room
  • Set different temperatures in different rooms, using zonal heating
  • Save money and energy, using zonal heating
  • Using timers to set certain temperatures at certain times during the day
  • Compatible with IFTTT
Product codes
This Mi Home Radiator Valve requires the Mi|Home Gateway to work, available seperately. Search QL CZFF and see bundles to buy together
Make your home smarter with Mi Home Radiator Valves
  • Take control of your heating, lighting and electrical devices wherever you are
  • FREE iOS and Android App, plus browser interface
  • Easy to fit to existing TRV body - just unscrew your existing TRV head - no plumber required
  • 1 Year battery life, dual thermostat, ultra quiet motor
  • Communicates current and target temperatures to the Mi|Home Gateway, as well as battery status
Mi|Home Smart Radiator Valves provide automatic control and zoning of your heating system. Each valve can be programmed by time and temperature, so you only heat the rooms you want to the temperature you specify. Use Geofencing and IFTTT to fully automate your heating. A true whole-of house Smart Home
Box Contains
  • 1 x Mi|Home Smart Radiator Valves
  • 2 X AA batteries
  • 1 spacer rings
  • 2 adapter collars
  • Instructions
Energenie Mi|Home Radiator Valve - radiator thermostat
Radiator thermostat
Functions
Control heating systems
Power Source
Internet of Things (IoT) Platform
Nest
Wireless
Frequency Band
434.3 MHz
4.5 cm x 4.5 cm x 11 cm
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Energenie Mi Home Radi...
