Energenie Mi Home Starter Pack
FREE DELIVERY
Key features
  • Control radiators to regulate heating in the room
  • Set different temperatures in different rooms, using zonal heating
  • Save money and energy, using zonal heating
  • Using timers to set certain temperatures at certain times during the day
  • Compatible with IFTTT
Product codes
Make your home smarter with Mi|Home! Alexa Controlled Smart Plugs
The Energenie Mi|Home Starter Pack contains a remote control, x3 control adapters and gateway. The Mi|Home adapters can be controlled via the Mi|Home app or web browser using the Mi|Home Gateway. This product receives commands from the Mi|Home gateway and doesn't send a confirmation of action back to it. The adapters can also be used with our other features such as timers. As well as timers, the Sockets can be controlled with IFTTT (If This Then That), this allows you to turn them on using the weather, ESPN, facebook to name but a few. It also means they can be used in conjunction with the Phillips Hue and Nest, for example.
The technical Info...
- Input voltage: 5VDC
- Input current: 150mA
- Power connection: MicroUSB (Power only)
- Ethernet connection: RJ45, cat5e patch cable
- Radio Frequency: 433MHz Band
- Certified by Amazon to work with Alexa (Echo, Dot, kindle, Fire)
Product Description Energenie Mi|Home Starter Pack - home automation kit
Product Type Home automation kit
Functions Energy use monitor, power measuring
Power Source Power adapter
Package Content Remote control, smart plug, gateway
Connectivity Wireless
Frequency Band 433 MHz
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Energenie Mi Home Star...
