Energenie MiHome Smart Pack - includes Gateway, 3 Smart Plugs...
FREE DELIVERY
Energenie MiHome Smart Pack - includes Gateway, 3 Smart Plugs and Smart Button
Product codes
MiHome Smart Pack, includes Gateway, 3 Smart Plugs and Smart Button, works with Amazon Echo and Google Home assistants
Starting a smart home has never been easier, and with the potential to grow to a full system to take control of your lighting, heating and appliances this is a great place to start.
The MiHome Gateway plugs in to your router and creates your smart home network. No I.T skills are needed as it’s plug and play; the free MiHome App will walk you through the steps in pictures.
Each of the three included smart plugs can be used with your existing lamps, appliances or devices. Simply set them up in the App in a few seconds and then control them from wherever you want.
The Smart Button allows you to control your smart plugs without reaching for your smartphone. It is easy to set up in the App and offers 3 functions from a single press, double click or long press. Set countdown timers or other triggers to control your smart plugs at the touch of a button.
If you have a Voice Assistant such as an Echo Dot or Google Home then you can even control your smart plugs by voice!
As MiHome is a full spec smart home system you can add additional smart plugs, light switches, heating controls and sensors at any time
MiHome Smart Pack Contents
  • 1 x MiHome Gateway, part number MIHO001
  • 1 x MiHome Click, part number MIHO089
  • 1 x Pack of 3 Smart Plugs, MIHO002
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Energenie MiHome Smart...
