Epson 3600 ANSI Lumens WXGA 3LCD Technology Meeting Room Proj...
£659.59
Delivery:
Standard: 1-3 working days
Key features
  • 3LCD technology and equally high white and colour light output
  • Deep, rich blacks and dense shadow areas
  • Built-in Wi-Fi
  • Lamp and filter life of 10,000 hours
  • Project from different sources with HDMI input and mobile connectivity
  • Portability: Portable
  • Stock Status: In Stock
Product codes
Bright, vivid content on a large scalable screen
View content like never before and pick out even the finest detail with crisp, clear images with a screen size up to 320 inches. The combination of a high brightness, high contrast ratio of 15,000:1, and HD Ready content provides superior image quality and a viewing experience that is easy on the eye, even in high ambient lighting conditions.
Years of uninterrupted meetings
With a lamp life and air filter maintence cycle of 10,000 hours in eco mode, users won't need to worry about maintenance for up to 5 years .
Installation and placement flexibility
Automatic vertical and manual horizontal keystone correction provide greater flexibility as to where the projector can be placed in the room for distortion-free images and the wide optical zoom adds to the flexibility.
Flexible connectivity for greater sharing
Built-in Wi-Fi enables easy and intuitive access to the projector from compatible smart devices using the iProjection app . Display content with the freedom to move around and engage with your audience. Split screen capability allows content from more than one device to be displayed simultaneously without the need for two separate display devices.
Product Description Epson EB-W42 - 3LCD projector - portable - 802.11n wireless
Device Type 3LCD projector - 720p
Colour Black, white
Built-in Devices Speaker
Brightness (White) 3600 lumens
Brightness (Colour) 3600 lumens
Contrast Ratio 15000:1 (dynamic)
Resolution WXGA (1280 x 800)
Native Aspect Ratio 16:10
Colour Support 1.07 billion colours
Bulb type UHE 210 Watt
Bulb life cycle Up to 6000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input RGB, S-Video, composite video IEEE 802.11n wireless
Speakers Speaker(s) - integrated
Environmental Standards TCO Certified Projectors 2
Power AC 120/230 V (50/60 Hz)
Power Consumption Operational 282 Watt
Dimensions (WxDxH) 30.2 cm x 23.7 cm x 8.2 cm
Weight 2.5 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson 3600 ANSI Lumens...
£659.59
