Epson 4000 ANSI Lumens WUXGA 3LCD Technology Installation Pro...
Epson 4000 ANSI Lumens WUXGA 3LCD Technology Installation Projecto
£3,712.15
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Maintenance-free laser technology delivers longer life and peace of mind
  • Full HD WUXGA resolution with Epson's 3LCD technology
  • Ease of connectivity and simple set-up
  • Share content from a range of devices simultaneously
  • Two displays in one - project images from different sources simultaneously
  • Portability: Non-portable
  • Stock Status: In Stock
Product codes
Bring the classroom to life with a scalable image up to 100 inches
Ensure students can read everything on the screen with this large scalable laser display, combining Full HD WUXGA resolution and 4,000 lumens of brightness. Epson's 3LCD technology delivers equally-high white and colour light output (CLO).
Hassle-free lessons
Ease of connectivity and simple set-up enables lessons to get underway without delay. Auto Power On starts up the device when a cable connection is detected. HDMI connectivity also means that students benefit from clearer, sharper content, and a 16W integrated speaker and microphone input remove the need for additional audio installation.
Collaborate seamlessly
Wireless connectivity via an optional USB dongle makes it easy to connect a range of mobile devices using Epson's iProjection app . Multi-PC projection software allows teachers and students to share content simultaneously. The moderator function allows teachers to remain in control, choosing what student content to display, including collaboration with laptops and mobile devices using whiteboard annotation. Dual-pen and finger-touch allow teachers and students to annotate directly onto the screen.
Split screen
Display content from two sources simultaneously, such as a lesson plan and live feed from a document camera, without needing two separate display devices.
Product Description Epson EB-710Ui - 3LCD projector - ultra short-throw - LAN
Device Type 3LCD projector - 1080p
Colour Grey, white
Built-in Devices Speaker
Brightness (White) 4000 lumens
Brightness (Colour) 4000 lumens
Contrast Ratio 2500000:1 (dynamic)
Resolution WUXGA (1920 x 1200)
Native Aspect Ratio 16:10
Colour Support 1.07 billion colours
Lens Ultra short-throw lens
Bulb type Laser diode
Bulb life cycle Up to 12000 hour(s) - normal mode , Up to 20000 hour(s) - economic mode
Video Input RGB, S-Video LAN
Speakers Speaker(s) - integrated
Power AC 120/230 V (50 - 60 Hz)
Power Consumption Operational 423 Watt
Dimensions (WxDxH) 49.4 cm x 43.7 cm x 17.5 cm
Weight 11.2 kg
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson 4000 ANSI Lumens...
£3,712.15
