Epson AcuLaser C9300DTN A3 Colour Laser Printer
£2,128.21
Delivery:
Key features
  • A3 colour laser printer
  • 4800RIT resolution, AAM technology
  • Duplex, extra paper tray
  • 100,000 page duty cycle
  • Type: Printer
  • Functionality: Printer
  • Output Type: Colour
  • Wireless Capability: Wired
  • Technology: Laser
Product codes
New technology - It offers Epson’s new Advanced Amplitude Modulation (AAM) screen technology to analyse dot placement and produce sharp images with well-defined edges.
High quality output - Epson's resolution improvement technology, AcuLaser Colour-RITech, eliminates uneven edges in text and delivers charts, graphics and even CAD schematics with clear, crisp tones.
Low TCO - It boasts Epson’s lowest cost-per-page for a laser in both mono and colour. This, in addition to its duplex capability which helps save up to 50% on paper usage, plus the ENERGY STAR-qualified reduced power consumption, mean that its TCO is very low.
Engineered for business - It has a compact footprint and the ability to print at up to A3 size in colour. Its print speed of up to 30ppm in A4 mono and colour helps boost productivity and a paper capacity of up to 2055 sheets saves on time refilling it. And the Gigabit Ethernet and PDL support with IPSec, IPv6 and SSL makes integration into complex IT environments hassle-free. It also offers automatic double-sided printing and an additional paper tray as standard.
High durability - It has a duty cycle of up to 100,000 pages, so businesses can be confident that their investment in the Epson range is a sound one.
Product Description Epson AcuLaser C9300DTN - printer - colour - laser
Printer Type Workgroup printer - laser - colour
Weight 51.7 kg
Media Size Class A3/Ledger
Max Media Size A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm)
Min Media Size (Custom) 75 mm x 98 mm
Max Media Size (Custom) 297 mm x 431.8 mm
Print Speed Up to 30 ppm - B/W - A4 (210 x 297 mm) , Up to 30 ppm - colour - A4 (210 x 297 mm) , Up to 21 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 21 ppm - colour duplex - A4 (210 x 297 mm)
Max Resolution (B&W) 1200 dpi
Image Enhancement Technology 4800RIT (Colour Resolution Improvement Technology)
Automatic Duplexing Yes
Interface USB, Gigabit LAN
Processor 400 MHz
RAM Installed (Max) 256 MB (1 GB) - DDR2 SDRAM
Language Simulation PCL 5C, PostScript 3, EPSON ESC/P 2, EPSON FX, PCL 6, EPSON ESC/P, PDF 1.6
Media Type Envelopes, plain paper
Total Media Capacity 955 sheets
Media Handling 250-sheet input tray, 550-sheet input tray, 155-sheet multipurpose tray
Monthly Duty Cycle (max) 100000 pages
Networking Print server - Ethernet, Fast Ethernet, Gigabit Ethernet - internal
Power AC 230V
System Requirements Microsoft Windows Server 2008 R2, Apple MacOS X 10.4.11 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
Manufacturer Warranty 1-year warranty
Dimensions (WxDxH) 50 cm x 53.8 cm x 56.1 cm
Accessories
Ink
Other bundles
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson AcuLaser C9300DT...
£2,128.21
