High performance
A high monthly duty cycle of up to 100,000 pages, fast print speed of 32ppm, plus a dot correction function and 1200dpi resolution, mean that the M7000DN is perfect for printing a wide range of business documents.
Easy integration
The M7000DN series offers compatibility for multiple users across many IT networks, making it ideal for sharing across business groups, with network Ethernet connectivity, IPv6, IPsec, PCL6 and PS3 emulations.
Versatile, reliable printing and productivity
The M7000DN allows effortless switching between different paper sizes, from envelopes to A3 documents, and it allows double-sided printing as standard for further versatility and to reduce paper consumption.
Optimised printing
Long-lasting toner supplies help optimise cost per page, resulting in a low TCO. This, combined with an ENERGY STAR-qualification for reduced power consumption and environmental impact, along with the Epson cartridge Return and Recycle program means that there is no compromise between cost and ecology.
Product Description | Epson AcuLaser M7000DN - printer - monochrome - laser | Printer Type | Workgroup printer - laser - monochrome | Weight | 22.8 kg | Media Size Class | A3/Ledger | Max Media Size | A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) | Min Media Size (Custom) | 75 mm x 98.4 mm | Max Media Size (Custom) | 297 mm x 508 mm | Print Speed | Up to 32 ppm - B/W , Up to 21.4 ppm - B/W duplex | Max Resolution (B&W) | 1200 dpi | Automatic Duplexing | Yes | Interface | USB, Gigabit LAN | Processor | 288 MHz | RAM Installed (Max) | 64 MB (320 MB) | Language Simulation | PCL 5E, PostScript 3, EPSON ESC/P 2, EPSON FX, PCL 6, EPSON ESC/P, PDF 1.6 | Media Type | Envelopes, plain paper | Total Media Capacity | 380 sheets | Media Handling | 150-sheet multipurpose tray, 230-sheet input tray | Monthly Duty Cycle (max) | 100000 pages | Networking | Print server - Ethernet, Fast Ethernet, Gigabit Ethernet - internal | Power | AC 230V | System Requirements | Linux, Microsoft Windows Server 2008 R2, Apple MacOS X 10.4.11 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits) | Manufacturer Warranty | 1-year warranty | Dimensions (WxDxH) | 51.8 cm x 46.4 cm x 33.3 cm |
General | |
Printer | |
Built-in Devices | Status LCD |
Connectivity Technology | Wired |
First Print Out Time B/W | 8.5 sec |
Processor | |
RAM | |
RAM Installed (Max) | 64 MB / 320 MB (max) |
Media Handling | |
Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), F4 |
Envelope Sizes | International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm) |
Media Weight | 60 g/m² - 216 g/m² |
Media Feeders | 1 x automatic - 150 sheets , 1 x automatic - 230 sheets |
Max Media Capacity | 1380 sheets |
Output Trays Capacity | 230 sheets |
Duty Cycle | |
Networking | |
Networking | Print server - internal |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Network / Transport Protocol | TCP/IP, AppleTalk, NetBEUI/NetBIOS, LPR/LPD, FTP, BOOTP, DHCP, DDNS |
Remote Management Protocol | SNMP, IPP, HTTP |
Security Protocols & Features | IPsec |
Expansion / Connectivity | |
Expansion Slots | Memory |
Connections | 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 |
Miscellaneous | |
Consumables Included | 1 x toner cartridge (black) |
Compliant Standards | EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, IEC 60950-1, EN 60950-1, IEC 60825-1, EN 60825-1 |
Power | |
Power Device | Power supply - internal |
Voltage Required | AC 230V |
Frequency Required | 50/60 Hz |
Power Consumption Operational | 544 Watt |
Power Consumption Stand by / Sleep | 82 Watt |
Software / System Requirements | |
Software Included | Drivers & Utilities, EPSON Web-to-Page, EpsonNet Print, EpsonNet Config |
OS Required | Linux, Microsoft Windows Server 2008 R2, Apple MacOS X 10.4.11 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits) |
Environmental Standards | |
ENERGY STAR | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - on-site |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 15 - 85% |
Sound Emission (Idle) | 33 dB |
Sound Emission (Operating) | 54 dB |
Dimensions & Weight | |
Width | 51.8 cm |
Depth | 46.4 cm |
Height | 33.3 cm |
Weight | 22.8 kg |
