Epson AcuLaser M7000DN A3 Mono Laser Printer
£1,244.60
Delivery:
Key features
  • Monthly duty cycle of 100,000 pages
  • Gigabit Ethernet, PCL6 and PS3, IPv6, IPSec
  • Holds A3 or A4, with low footprint
  • 1200 dpi, dot correction function
  • Long lasting supplies, duplex unit
Product codes
High performance
A high monthly duty cycle of up to 100,000 pages, fast print speed of 32ppm, plus a dot correction function and 1200dpi resolution, mean that the M7000DN is perfect for printing a wide range of business documents.
Easy integration
The M7000DN series offers compatibility for multiple users across many IT networks, making it ideal for sharing across business groups, with network Ethernet connectivity, IPv6, IPsec, PCL6 and PS3 emulations.
Versatile, reliable printing and productivity
The M7000DN allows effortless switching between different paper sizes, from envelopes to A3 documents, and it allows double-sided printing as standard for further versatility and to reduce paper consumption.
Optimised printing
Long-lasting toner supplies help optimise cost per page, resulting in a low TCO. This, combined with an ENERGY STAR-qualification for reduced power consumption and environmental impact, along with the Epson cartridge Return and Recycle program means that there is no compromise between cost and ecology.
Product Description Epson AcuLaser M7000DN - printer - B/W - laser
Printer Type Workgroup printer - laser - B/W
Weight 22.8 kg
Media Size Class A3/Ledger
Max Media Size A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm)
Min Media Size (Custom) 75 mm x 98.4 mm
Max Media Size (Custom) 297 mm x 508 mm
Print Speed Up to 32 ppm - B/W , Up to 21.4 ppm - B/W duplex
Max Resolution (B&W) 1200 dpi
Automatic Duplexing Yes
Interface USB, Gigabit LAN
Processor 288 MHz
RAM Installed (Max) 64 MB (320 MB)
Language Simulation PCL 5E, PostScript 3, EPSON ESC/P 2, EPSON FX, PCL 6, EPSON ESC/P, PDF 1.6
Media Type Envelopes, plain paper
Total Media Capacity 380 sheets
Media Handling 150-sheet multipurpose tray, 230-sheet input tray
Monthly Duty Cycle (max) 100000 pages
Networking Print server - Ethernet, Fast Ethernet, Gigabit Ethernet - internal
Power AC 230V
System Requirements Linux, Microsoft Windows Server 2008 R2, Apple MacOS X 10.4.11 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
Manufacturer Warranty 1-year warranty
Dimensions (WxDxH) 51.8 cm x 46.4 cm x 33.3 cm
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson AcuLaser M7000DN...
£1,244.60
