Epson ColorWorks TM-C7500 Industrial Colour DURABrite Ultra I...
Epson ColorWorks TM-C7500 Industrial Colour DURABrite Ultra Inkjet Label Printer
£7,341.92
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • PrecisionCore printhead for consistent results and long printer lifetime
  • Streamline label production by printing your colour labels on-demand
  • Print speeds of up to 300mm/sec at image resolution of 600x1200dpi
  • Permanent printhead and NVT for self-maintenance
  • New ESC/Label programming language for integration with virtually any OS
  • Type: Printer
  • Functionality: Printer
  • Output Type: Colour
  • Wireless Capability: Wired
  • Technology: Ink-jet
Product codes
Reliable and consistent results{b
}The C7500 can help manufacturers produce consistent, high-quality labels in-house and on-demand. The printer features the new PrecisionCore printhead to ensure reliable, high-quality results. Our unique Nozzle Verification Technology (NVT) and dot substitution help prevent misprints and dead pixels for consistent printouts.{b
}Fast speeds{b
}Produce a range of high-quality labels, fast including those for food and beverage products, packaging and boxes, as well as EU Energy Labels and GHS Labels. With print speeds of up to 300mm/sec, you can now print labels in full colour, at the same speed as some incumbent thermal monochrome printers.{b
}{b
Cost-effective}{b
}Printing labels on-demand helps eliminate costs associated with pre-printing, such as label waste and large label inventory. High-capacity, individual ink cartridges mean only the colour used will need to be replaced, offering very low cost per print. The permanent printhead offers significant cost savings, and a guaranteed peace of mind as none of its major components will need replacing for at least 500km worth of printing┬╣.{b
}Easy to use with minimal maintenance{b
}With its LCD control panel, set-up is easy. Our newest printer command set, ESC/Label, allows integration with virtually any operating system. The device also comes with a full range of software utilities to support printer deployment. NVT also helps to prevent clogged nozzles.
Product Description Epson ColorWorks TM-C7500 - label printer - colour - ink-jet
Printer Type Label printer - ink-jet - colour
Weight 36.7 kg
Inkjet Technology Epson PrecisionCore TFP
Ink Palette Supported (Colours) 4-ink - cyan, magenta, yellow, black
Max Media Size Continuous paper 50 mm - 112 mm (width)
Min Media Size (Custom) 50 mm
Max Media Size (Custom) 112 mm
Print Speed Up to 300 mm/sec - 108 mm width
Max Resolution (B&W) 600 x 1200 dpi
Interface USB 2.0, Gigabit LAN
Media Type Labels, continuous paper labels, die cut labels
Features Black Mark sensor
Networking Print server
Power AC 120/230 V
Dimensions (WxDxH) 39.2 cm x 59.8 cm x 39.7 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson ColorWorks TM-C7...
£7,341.92
