Reliable and consistent results{b
}The C7500 can help manufacturers produce consistent, high-quality labels in-house and on-demand. The printer features the new PrecisionCore printhead to ensure reliable, high-quality results. Our unique Nozzle Verification Technology (NVT) and dot substitution help prevent misprints and dead pixels for consistent printouts.{b
}Fast speeds{b
}Produce a range of high-quality labels, fast including those for food and beverage products, packaging and boxes, as well as EU Energy Labels and GHS Labels. With print speeds of up to 300mm/sec, you can now print labels in full colour, at the same speed as some incumbent thermal monochrome printers.{b
}{b
Cost-effective}{b
}Printing labels on-demand helps eliminate costs associated with pre-printing, such as label waste and large label inventory. High-capacity, individual ink cartridges mean only the colour used will need to be replaced, offering very low cost per print. The permanent printhead offers significant cost savings, and a guaranteed peace of mind as none of its major components will need replacing for at least 500km worth of printing¹.{b
}Easy to use with minimal maintenance{b
}With its LCD control panel, set-up is easy. Our newest printer command set, ESC/Label, allows integration with virtually any operating system. The device also comes with a full range of software utilities to support printer deployment. NVT also helps to prevent clogged nozzles.
Product Description | Epson ColorWorks TM-C7500 - label printer - colour - ink-jet | Printer Type | Label printer - ink-jet - colour | Weight | 36.7 kg | Inkjet Technology | Epson PrecisionCore TFP | Ink Palette Supported (Colours) | 4-ink - cyan, magenta, yellow, black | Max Media Size | Continuous paper 50 mm - 112 mm (width) | Min Media Size (Custom) | 50 mm | Max Media Size (Custom) | 112 mm | Print Speed | Up to 300 mm/sec - 108 mm width | Max Resolution (B&W) | 600 x 1200 dpi | Interface | USB 2.0, Gigabit LAN | Media Type | Labels, continuous paper labels, die cut labels | Features | Black Mark sensor | Networking | Print server | Power | AC 120/230 V | Dimensions (WxDxH) | 39.2 cm x 59.8 cm x 39.7 cm |
General | |
Printer | |
Nozzle Configuration | 600 nozzles (colour) |
Ink Cartridge Configuration | 4 cartridges (1 each: cyan, magenta, yellow, black) |
Ink Type | Epson DURABrite Ultra inks |
Print Speed | Up to 300 mm/sec - 600x1200 dpi - 108 mm width |
Built-in Devices | Status LCD |
Connectivity Technology | Wired |
Auto Cutter | Yes |
Media Handling | |
Media Sizes | Continuous paper 50 mm - 112 mm (width) |
Max Printing Width | 108 mm |
Roll Maximum Outer Diameter | 203.2 mm |
Networking | |
Expansion / Connectivity | |
Connections | 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 |
Miscellaneous | |
Cables Included | 1 x USB cable |
Consumables Included | 1 x ink cartridge (black) , 1 x ink cartridge (yellow) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x maintenance box |
Media Included | Roll of media |
Power | |
Power Device | Power supply - internal |
Voltage Required | AC 120/230 V |
Frequency Required | 50 - 60 Hz |
Power Consumption Operational | 86 Watt |
Power Consumption Stand by | 4 Watt |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% |
Dimensions & Weight | |
Width | 39.2 cm |
Depth | 59.8 cm |
Height | 39.7 cm |
Weight | 36.7 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 57.5 cm |
Depth (Shipping) | 79.3 cm |
Height (Shipping) | 54 cm |
Weight (Shipping) | 44 kg |
