Epson DFX 9000N Mono Dot-Matrix Printer
£4,337.13
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Fastest 9-pin heavy duty dot matrix printer in its class
  • Handles demanding workloads with 1,550cps print speed
  • Hard working with 133 million lines print volume
  • High durability with MTBF of 20,000 power on hours
  • Prints up to 10 part forms (1 original + 9 copies)
  • Long ribbon life of 15 million characters
  • Standard USB, Serial and Parallel interfaces (optional network, twinax, coax)
  • Flexible paper handling with two tractors as standard
  • Type: Printer
  • Functionality: Printer
  • Output Type: Monochrome
  • Wireless Capability: Wired
  • Technology: Dot-matrix
Product codes
Documents
The Epson DFX-9000 is a high print volume printer providing an unprecedented level of speed and reliability for the most demanding business. Its advanced paper handling accommodates a variety of paper types while the standard front and rear push tractors can be switched easily between different types of continuous paper. An optional perforation cutter provides paper finishing capabilities.
Product Description Epson DFX 9000N - printer - monochrome - dot-matrix
Printer Type Personal printer - dot-matrix - 9 pin - monochrome
Weight 34 kg
Max Media Size Continuous paper 76.2 mm - 419.1 mm (width)
Max Media Size (Custom) 419 mm
Print Speed Up to 1550 char/sec - max speed , Up to 1450 char/sec - max speed , Up to 1320 char/sec - draft , Up to 1320 char/sec - draft , Up to 330 char/sec - near letter , Up to 330 char/sec - near letter
Max Resolution (B&W) 240 x 144 dpi
Interface Parallel, USB, LAN, serial
RAM Installed (Max) 128 KB
Barcodes Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Code 128, Interleaved 2 of 5, Postnet
Media Type Labels, continuous forms
Networking Print server - Ethernet, Fast Ethernet
Power AC 120/230 V
Microsoft Certification Works with Windows Vista
Manufacturer Warranty 1-year warranty
Dimensions (WxDxH) 70 cm x 37.8 cm x 36.3 cm
Resources
The following resources are available for the Epson DFX 9000N Mono Dot-Matrix Printer
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson DFX 9000N Mono D...
£4,337.13
