Epson Discproducer PP-50BD BD Printer
£2,740.59
Delivery:
Key features
  • Dependable archiving
  • Low printing cost and accurate unattended production ensured
  • Burn, print, publish dustproof and secured
  • Ensures extremely reliable pick and move of BD media
  • Six cartridge single ink system for impressive high class printouts
  • Outstanding accuracy of burned data with professional archival grade drives
  • Type: Printer
  • Functionality: Printer
  • Output Type: Monochrome
  • Wireless Capability: Wired
  • Technology: Ink-jet
Product codes
High-quality output
The PP-50BD delivers high-quality, photo-realistic printing on the CD/DVD/BD surface. Epson's Micro Piezo printhead and 6-colour inks produce ultra-fine colour gradations and razor-sharp text, even in very small font sizes.
Low cost per finished disc
Thanks to Epson's individual inks system, the cost of each produced media is low as you only need to replace the colour used. Depending on the print image, you can produce over 1,000 fully-covered discs from one set of cartridges.
Dependable operation
Epson has drawn on its expertise in manufacturing robots to develop the patented AcuGrip robotic arm, which ensures that only one CD/DVD/BD is grabbed at a time – even if they're stuck together. This allows you to leave production runs unsupervised. To ensure trouble-free operation for years to come, the PP-50BD has a dust-proof body and minimal moving parts.
Simple to use
The PP-50BD couldn't be easier to use – it's conveniently controlled from the front, and its LED system shows the ink level status for each individual colour. The included software is user-friendly too, with pre-defined templates and images, so you don't need to be an expert to use it.
Easy installation
One of the smallest disc publishing solutions on the market, the fully-stackable PP-50BD has a compact footprint and measures only 38cm wide to fit easily onto a shelf or desktop.
Product Description Epson Discproducer PP-50BD - BD duplicator - USB 2.0 - external
Device Type BD duplicator - external
Interface USB 2.0
Removable Media Capacity 50
Dimensions (WxDxH) 37.7 cm x 46.5 cm x 32.4 cm
Weight 21 kg
Optical Storage 1 x BD-RE
Write Speed 40x (CD) / 12x (DVD±R) / 8x (DVD±R DL)
Power AC 230V (50/60 Hz)
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson Discproducer PP-...
£2,740.59
