Exceptional image quality
Enjoy superb image quality, impressive natural colours with an equally high white and colour light output of 3,000 lumens thanks to Epson's 3LCD technology. True Colours technology delivers a faithful reproduction of colours as they are meant to be and, with a 10,000:1 contrast ratio, projected images are crisp and clear.
Easy set-up
Automatic vertical and horizontal keystone correction makes it easy to set up the projector almost anywhere. The short throw ratio projects a large image from a shorter distance so that all meeting participants can be seated behind the projector as the front exhaust directs heat away from them. Thanks to its Auto Power On feature, the projector turns on when it detects signal input.
Smarter presentations
Users can view two data sources side by side with split screen, and MHL can show high-quality video and audio content from mobile devices while charging them at the same time.
True portability
The ultra-slim form factor and lightweight design makes this the ideal projector for anyone on the move. A carry case is included and the projector fits easily into a standard laptop bag.
Product Description | Epson EB-1780W - LCD projector - portable - 802.11n wireless / NFC / Miracast | Device Type | LCD projector - 720p | Colour | Black, white | Localisation | United Arab Emirates, United Kingdom | Brightness (White) | 3000 lumens | Brightness (Colour) | 3000 lumens | Contrast Ratio | 10000:1 (dynamic) | Resolution | WXGA (1280 x 800) | Native Aspect Ratio | 16:10 | Colour Support | 1.07 billion colours | Bulb type | 206 Watt | Bulb life cycle | Up to 4000 hour(s) - normal mode , Up to 7000 hour(s) - economic mode | Video Input | RGB, composite video IEEE 802.11n wireless / NFC / Miracast | Speakers | Speaker(s) - integrated | Environmental Standards | TCO Certified Projectors 2 | Power | AC 120/230 V (50 - 60 Hz) | Power Consumption Operational | 277 Watt | Dimensions (WxDxH) | 29.2 cm x 21.3 cm x 4.4 cm | Weight | 1.77 kg | Manufacturer Warranty | 2-year warranty |
General | |
Networking | 802.11b/g/n, NFC |
Enclosure Colour | Black, white |
Projector | |
Brightness (Reduced) | 1900 lumens |
Image Size | 76 cm - 762 cm |
Projection Distance | 0.7 m - 8.2 m |
Throw Ratio | 1.04 - 1.26:1 |
Resolution | WXGA - WXGA (1280 x 800) |
Features | sRGB colour profile, Blackboard Mode, Auto Vertical Keystone, Split Screen, DICOM Simulation Mode, Dynamic Mode, Theater Mode |
Lens | |
Focus Type | Manual |
Lens Aperture | F/1.58-1.7 |
Zoom Type | Manual |
Zoom Factor | 1.2x |
Keystone Correction Direction | Horizontal, vertical |
Vertical Keystone Correction | -30 / +30 |
Horizontal Keystone Correction | -30 / +30 |
Video Input | |
Analogue video Signal | RGB, composite video |
Video Interfaces | VGA, HDMI, composite video, MHL |
LAN and Wireless Image Transferring Protocols | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, NFC (Near Field Communication), Miracast |
Speakers | |
Type | Integrated |
Sound Output Mode | Mono |
Output Power / Channel | 1 Watt |
Speakers | 1 x mixed channel |
Expansion / Connectivity | |
Interfaces | 1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B (management) , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x composite video input - RCA |
Miscellaneous | |
Included Accessories | Carrying case, wireless remote control |
Cables Included | 1 x VGA cable |
Security Features | Security lock slot (cable lock sold separately), password protection |
Environmental Standards | |
TCO Certified | TCO Certified Projectors 2 |
Power | |
Power Source | AC |
Nominal Voltage | AC 120/230 V (50 - 60 Hz) |
Power Consumption Stand by | 0.34 Watt |
Software / System Requirements | |
Software Included | EasyMP Multi PC Projection |
Dimensions & Weight | |
Width | 29.2 cm |
Depth | 21.3 cm |
Height | 4.4 cm |
Weight | 1.77 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year / 1000 hours |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
Sound Emission | 39 dBA |
Sound Emission (Economic Mode) | 30 dBA |
