Epson EB-2042 XGA 3LCD 4400 Lumens Projector
£627.22
22 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Reach up to 300 inches with a scalable display
  • Equally high White and Colour Light Output of 4,400 lumens
  • Enjoy this XGA projector
  • Showcase your content every day for six years
  • Easy to position with keystone slider
  • Portability: Non-portable
  • Stock Status: In Stock
Product codes
Upgrade your display
Get everyone to sit up and take notice with a display that can reach up to 300 inches. From delivering presentations to streaming box sets at home, experience a display that's up to three times brighter than competitor products, thanks to 3LCD technology . In addition to its bright and vivid colours, the 15,000:1 contrast ratio produces defined shadows and deep blacks.
Myth-busting brightness
Bright rooms are no match for this projector – with 4,400 lumens, this powerful yet affordable model delivers exceptionally bright yet colourful images with clear details. It utilises Epson's renowned 3LCD technology, which produces an equally high White and Colour Light Output.
Long-lasting solution
Durable and affordable, this model's long-lasting lamp light source means you'll be able to project your content every day for six years .
Set up has never been so easy
Keep your cool setting up this hassle-free projector. Keystone correction lets you position the image, while the array of inputs and outputs ensure that it's easy to access content. It includes two HDMI inputs (including one MHL), two VGA in, VGA out, and it's also network enabled via RJ45. Thanks to the optional ELPAP10 adapter, it also offers Wi-Fi connectivity, allowing you to share content from a smart device using the iProjection app.
Product Description Epson EB-2042 - 3LCD projector - LAN
Device Type 3LCD projector
Colour White
Built-in Devices Speaker
Brightness (White) 4400 lumens
Brightness (Colour) 4400 lumens
Contrast Ratio 15000:1 (dynamic)
Resolution XGA (1024 x 768)
Native Aspect Ratio 4:3
Colour Support 1.07 billion colours
Bulb type UHE 230 Watt
Bulb life cycle Up to 5500 hour(s) - normal mode , Up to 12000 hour(s) - economic mode
Video Input RGB, composite video LAN
Speakers Speaker(s) - integrated
Environmental Standards TCO Certified Projectors 2
Power AC 120/230 V (50 - 60 Hz)
Power Consumption Operational 331 Watt
Dimensions (WxDxH) 30.9 cm x 29.3 cm x 105 cm
Weight 3 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson EB-2042 XGA 3LCD...
£627.22
