Upgrade your display
Get everyone to sit up and take notice with a display that can reach up to 300 inches. From delivering presentations to streaming box sets at home, experience a display that's up to three times brighter than competitor products, thanks to 3LCD technology . In addition to its bright and vivid colours, the 15,000:1 contrast ratio produces defined shadows and deep blacks.
Myth-busting brightness
Bright rooms are no match for this projector – with 4,400 lumens, this powerful yet affordable model delivers exceptionally bright yet colourful images with clear details. It utilises Epson's renowned 3LCD technology, which produces an equally high White and Colour Light Output.
Long-lasting solution
Durable and affordable, this model's long-lasting lamp light source means you'll be able to project your content every day for six years .
Set up has never been so easy
Keep your cool setting up this hassle-free projector. Keystone correction lets you position the image, while the array of inputs and outputs ensure that it's easy to access content. It includes two HDMI inputs (including one MHL), two VGA in, VGA out, and it's also network enabled via RJ45. Thanks to the optional ELPAP10 adapter, it also offers Wi-Fi connectivity, allowing you to share content from a smart device using the iProjection app.
Product Description | Epson EB-2042 - 3LCD projector - LAN | Device Type | 3LCD projector | Colour | White | Built-in Devices | Speaker | Brightness (White) | 4400 lumens | Brightness (Colour) | 4400 lumens | Contrast Ratio | 15000:1 (dynamic) | Resolution | XGA (1024 x 768) | Native Aspect Ratio | 4:3 | Colour Support | 1.07 billion colours | Bulb type | UHE 230 Watt | Bulb life cycle | Up to 5500 hour(s) - normal mode , Up to 12000 hour(s) - economic mode | Video Input | RGB, composite video LAN | Speakers | Speaker(s) - integrated | Environmental Standards | TCO Certified Projectors 2 | Power | AC 120/230 V (50 - 60 Hz) | Power Consumption Operational | 331 Watt | Dimensions (WxDxH) | 30.9 cm x 29.3 cm x 105 cm | Weight | 3 kg | Manufacturer Warranty | 2-year warranty |
General | |
Networking | Ethernet |
Enclosure Colour | White |
Projector | |
Brightness (Reduced) | 2490 lumens |
Image Size | 76 cm - 762 cm |
Throw Ratio | 1.38 - 2.24:1 |
Resolution | XGA - XGA (1024 x 768) |
Max Sync Rate (V x H) | 120 Hz |
Features | Blackboard Mode, EPSON 3LCD technology, Dynamic Mode, Presentation Mode |
Lens | |
Focus Type | Manual |
Lens Aperture | F/1.51-1.99 |
Zoom Type | Manual |
Zoom Factor | 1.6x |
Keystone Correction Direction | Horizontal, vertical |
Vertical Keystone Correction | -30 / +30 |
Horizontal Keystone Correction | -30 / +30 |
Video Input | |
Analogue video Signal | RGB, composite video |
Video Interfaces | VGA, HDMI, composite video, MHL |
LAN and Wireless Image Transferring Protocols | Wired LAN |
Speakers | |
Type | Integrated |
Sound Output Mode | Mono |
Output Power / Channel | 16 Watt |
Speakers | 1 x mixed channel |
Expansion / Connectivity | |
Interfaces | 1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B (management) , 1 x serial RS-232C , 1 x network - RJ-45 , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - RCA x 2 , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x microphone |
Miscellaneous | |
Included Accessories | Wireless remote control, HDMI cable clamp |
Cables Included | 1 x VGA cable |
Security Features | Security lock slot (cable lock sold separately), password protection, Wireless LAN Lock |
Environmental Standards | |
TCO Certified | TCO Certified Projectors 2 |
Power | |
Power Source | AC |
Nominal Voltage | AC 120/230 V (50 - 60 Hz) |
Power Consumption Stand by | 0.2 Watt |
Dimensions & Weight | |
Width | 30.9 cm |
Depth | 29.3 cm |
Height | 105 cm |
Weight | 3 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year / 1000 hours |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% |
Sound Emission | 37 dBA |
Sound Emission (Economic Mode) | 28 dBA |
