Epson EB-2142W WXGA 3LCD 4200 Lumens projector
£975.92
Delivery:
Standard: 1-3 working days
Key features
  • HD-ready WXGA resolution with Epson's 3LCD technology
  • Outstanding 4,200-lumen brightness
  • Dual HDMI and built-in wireless connectivity
  • Quick and easy access to a variety of useful functions
  • Up to 12,000 hours in eco mode
  • Portability: Non-portable
  • Stock Status: In Stock
Product codes
Up to 280-inch display and outstanding quality
HD-ready WXGA resolution combined with Epson's 3LCD technology ensures high-quality content has more vivid colours and brighter images. HDMI connectivity guarantees sharper and clearer content, even at the maximum image size of 280 inches.
Simple set-up and connectivity
Offers auto power-on and an array of connectivity options including two HDMI connections and built-in wireless LAN connectivity to stream content from laptops or mobile devices. Compatible with iProjection software for easy connectivity and content sharing.
Keep costs down
Project for longer with improved reliability and a longer lamp life of up to 12,000 hours in eco mode.
Home screen
The home screen offers quick and easy access to a variety of useful functions, such as choosing connection sources. Wireless connections can also be made easily using the information on screen.
Value added flexibility
The Multi-PC projection software bundled with the EB-2142W makes it possible to connect with up to 50 computers and partition the screen for split-screen projection capability - offering far better cost-effectiveness and flexibility than a flat-panel display.
Product Description Epson EB-2142W - 3LCD projector - LAN
Device Type 3LCD projector - 720p
Colour White
Built-in Devices Speaker
Brightness (White) 4200 lumens
Brightness (Colour) 4200 lumens
Contrast Ratio 15000:1 (dynamic)
Resolution WXGA (1280 x 800)
Native Aspect Ratio 16:10
Colour Support 1.07 billion colours
Bulb type 230 Watt
Bulb life cycle Up to 6000 hour(s) - normal mode , Up to 12000 hour(s) - economic mode
Video Input LAN
Speakers Speaker(s) - integrated
Power AC 230V (50 - 60 Hz)
Power Consumption Operational 331 Watt
Dimensions (WxDxH) 30.9 cm x 28.2 cm x 9 cm
Weight 3.1 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson EB-2142W WXGA 3L...
£975.92
