Epson EB-2245U 4,200 lumens WUXGA Gesture presenter Wi-Fi Cor...
Epson EB-2245U 4,200 lumens WUXGA Gesture presenter Wi-Fi Corporat
Product codes
Outstanding quality display of up to 260 inches
Full HD resolution combined with Epson's 3LCD technology ensures high-quality content has more vivid colours and brighter images. HDMI connectivity guarantees sharper and clearer presentations delivered on a scalable image size of up to 260 inches.
Simple setup and multiple connectivity
The EB-2245U offers a wide range of connectivity options, including screen mirroring, wireless LAN and two HDMI inputs. Setup is easy too, thanks to features including auto-power-on, focus help, keystone correction and screen fit - delivering presentations quickly and efficiently.
Home screen
The home screen offers quick and easy access to a variety of useful functions, such as connection sources. Wireless connections can also be made easily using the information on screen.
Gesture Presenter
Change slides by simply moving your hand, making even smarter presentations a reality by liberating the user from their remote control or mouse.
Value-added flexibility
The Multi-PC projection software bundled with the EB-2245U makes it possible to connect up to 50 computers and partition the screen for split-screen projection capability - offering far better cost-effectiveness and flexibility than a flat-panel display.
Product Description Epson EB-2245U - LCD projector - 802.11n wireless / LAN
Device Type LCD projector - 1080p
Colour White
Brightness (White) 4200 lumens
Brightness (Colour) 4200 lumens
Contrast Ratio 400:1 / 15000:1 (dynamic)
Resolution WUXGA (1920 x 1200)
Native Aspect Ratio 16:10
Colour Support 1.07 billion colours
Bulb type 300 Watt
Bulb life cycle Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input RGB, composite video IEEE 802.11n wireless / LAN
Speakers Speaker(s) - integrated
Power AC 230V (50 - 60 Hz)
Power Consumption Operational 410 Watt
Dimensions (WxDxH) 37.7 cm x 29.1 cm x 11 cm
Weight 4.8 kg
Manufacturer Warranty 3 years warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson EB-2245U 4,200 l...
