Outstanding quality display of up to 300 inches
Full HD resolution combined with Epson's 3LCD technology ensures high-quality content has more vivid colours and brighter images. HDMI connectivity guarantees sharper and clearer presentations delivered on a scalable image size of up to 300 inches.
Simple set-up and multiple connectivity
The EB-2247U offers a wide range of connectivity options, including screen mirroring, wireless LAN and two HDMI inputs. Set-up is easy too, thanks to features including auto-power-on, focus help, keystone correction and screen fit - delivering presentations quickly and efficiently. Compatible with iProjection software for easy connectivity with mobile devices.
Home screen
The home screen offers quick and easy access to a variety of useful functions, such as choosing connection sources. Wireless connections can also be made easily using the information on screen.
Value-added flexibility
The Multi-PC projection software bundled with the EB-2247U makes it possible to connect up to 50 computers and partition the screen for split-screen projection capability - offering far better cost-effectiveness and flexibility than a flat-panel display.
Product Description | Epson EB-2247U - 3LCD projector - 802.11n wireless / LAN | Device Type | 3LCD projector - 1080p | Colour | White | Brightness (White) | 4200 lumens | Brightness (Colour) | 4200 lumens | Contrast Ratio | 15000:1 (dynamic) | Resolution | WUXGA (1920 x 1200) | Native Aspect Ratio | 16:10 | Colour Support | 1.07 billion colours | Bulb type | 230 Watt | Bulb life cycle | Up to 6000 hour(s) - normal mode , Up to 12000 hour(s) - economic mode | Video Input | RGB, composite video, component video IEEE 802.11n wireless / LAN | Speakers | Speaker(s) - integrated | Environmental Standards | TCO Certified Projectors 2 | Power | AC 230V (50 - 60 Hz) | Power Consumption Operational | 331 Watt | Dimensions (WxDxH) | 30.9 cm x 28.2 cm x 9 cm | Weight | 3.2 kg | Manufacturer Warranty | 3-year warranty |
General | |
Networking | 802.11b/g/n, Ethernet |
Enclosure Colour | White |
Projector | |
Brightness (Reduced) | 2410 lumens |
Image Size | 76 cm - 762 cm |
Projection Distance | 1.5 m - 8.9 m |
Throw Ratio | 1.39 - 2.23:1 |
Resolution | WUXGA - WUXGA (1920 x 1200) |
Max Sync Rate (V x H) | 240 Hz |
Features | sRGB colour profile, Blackboard Mode, Auto Vertical Keystone, EPSON 3LCD technology, Direct Power On, Direct Power Off, Dynamic Mode, Theater Mode |
Lens | |
Focus Type | Manual |
Lens Aperture | F/1.5-2.0 |
Keystone Correction Direction | Horizontal, vertical |
Vertical Keystone Correction | -30 / +30 |
Horizontal Keystone Correction | -30 / +30 |
Video Input | |
Analogue video Signal | RGB, composite video, component video |
Video Interfaces | VGA, HDMI, composite video, MHL |
LAN and Wireless Image Transferring Protocols | IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11n |
Speakers | |
Type | Integrated |
Sound Output Mode | Mono |
Output Power / Channel | 16 Watt |
Speakers | 1 x mixed channel |
Expansion / Connectivity | |
Interfaces | 1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B (management) , 1 x serial RS-232C , 1 x network - RJ-45 , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - RCA x 2 , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x microphone input - mini-phone 3.5 mm |
Miscellaneous | |
Included Accessories | Wireless remote control, wireless LAN unit |
Cables Included | 1 x VGA cable |
Security Features | Security lock slot (cable lock sold separately), password protection, Wireless LAN Lock |
Environmental Standards | |
TCO Certified | TCO Certified Projectors 2 |
Power | |
Power Source | AC |
Nominal Voltage | AC 230V (50 - 60 Hz) |
Power Consumption Stand by | 2 Watt |
Software / System Requirements | |
Software Included | EasyMP Multi PC Projection |
Dimensions & Weight | |
Width | 30.9 cm |
Depth | 28.2 cm |
Height | 9 cm |
Weight | 3.2 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years / 8000 hours , Limited warranty - lamp - 1 year / 1000 hours |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% |
Sound Emission | 37 dBA |
Sound Emission (Economic Mode) | 29 dBA |
