Epson EB-535w Short Throw WXGA 3400 Lumens Projector
£915.09
27 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Epson's 3LCD technology displays brighter images and more accurate colours
  • Projected image can be seen clearly even in brightly-lit rooms
  • Increased contrast ratio of 16,000:1
  • 10,000 hours in eco mode / 5,000 hours in normal mode
  • Horizontal and vertical keystone correction for off-centre and uneven placement
  • Brightness: 3400ANSI lumens
  • Portability: Non-portable
  • Stock Status: In Stock
Product codes
High-quality image
Complete with our 3LCD technology, the EB-535W displays superior-quality, bright images with more accurate colours. The image can be seen even in brightly-lit rooms thanks to an equally high white and colour light output. Image detail is clear thanks to a high contrast ratio and our new short throw lens means sharper images and improved focus.
More value for your money
The lamp in the EB-535W now lasts up to 10,000 hours in eco mode. The projector even conserves power during presentations by automatically adjusting the light output depending on the content. The A/V mute function pauses the presentation and dims the lamp by 70% to conserve energy while the projector is not in use. The projectors' built-in 16w speaker means audio content can be played directly through the projector, without the need for additional external speakers. The microphone input transforms the projector into a PA system, meaning presenters can be easily heard in a classroom environment.
Easy to set up and use
The EB-535W has both horizontal and vertical keystone correction to achieve a perfectly shaped image and help avoid distortion. When setting up several projectors, the OSD settings can be copied from one projector to many others meaning you don't need to set up projectors individually. Multi-PC projection software allows content from four devices, including PC's, tablets, smart phones, to be displayed simulatenously.
Product Description Epson EB-535W - 3LCD projector - LAN
Device Type 3LCD projector - 720p
Built-in Devices Speaker, 0.59-inch TFT LCD
Brightness (White) 3400 lumens
Brightness (Colour) 3400 lumens
Contrast Ratio 16000:1 (dynamic)
Resolution WXGA (1280 x 800)
Native Aspect Ratio 16:10
Colour Support 1.07 billion colours
Bulb type 215 Watt
Bulb life cycle Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input RGB, S-Video, composite video, component video LAN
Speakers Speaker(s) - integrated
Environmental Standards TCO Certified Projectors 2
Power AC 120/230 V (50 - 60 Hz)
Power Consumption Operational 298 Watt
Dimensions (WxDxH) 34.4 cm x 31.5 cm x 9.4 cm
Weight 3.7 kg
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson EB-535w Short Th...
£915.09
