Epson EB-536wi Short Throw Interactive WXGA 3400 Lumens Proje...
Epson EB-536wi Short Throw Interactive WXGA 3400 Lumens Projector
£1,194.92
Delivery:
Standard: 1-3 working days
Key features
  • Epson's 3LCD technology displays brighter images and more accurate colours
  • Screen can be seen clearly even in brightly-lit rooms
  • Increased contrast ratio of 16,000:1
  • Projects a larger image in a shorter distance
  • 10,000 hours in eco mode / 5,000 hours in normal mode
  • Brightness: 3400ANSI lumens
  • Portability: Non-portable
  • Stock Status: In Stock
Product codes
Documents
High-quality image
Complete with our 3LCD technology, the EB-536Wi displays superior-quality, bright images with more accurate colours. The image can be seen even in brightly-lit rooms thanks to an equally high white and colour light output. Image detail is clear thanks to a high contrast ratio and our new short throw lens means sharper images and improved focus.
More value for your money
The lamp in the EB-536Wi now lasts up to 10,000 hours in eco mode. The projector even conserves power during presentations by automatically adjusting the light output depending on the content. The A/V mute function pauses the presentation and dims the lamp by 70% to conserve energy while the projector is not in use. The projectors' built-in 16w speaker means audio content can be played directly through the projector, without the need for additional external speakers. The microphone input transforms the projector into a PA system, meaning presenters can be easily heard in a classroom environment.
Easy to use interactivity
Driverless installation and auto calibration makes setting up the EB-536Wi quick and easy. The EB-536Wi features dual pen capability, meaning two users can annotate across the entire screen area simultaneously using separate attributes . The interactive pens are now also faster-syncing and more accurate for smooth, precise writing. Easy Interactive Tools software provides users with a wide-range of interactive features.
Product Description Epson EB-536WI - 3LCD projector - LAN
Device Type 3LCD projector - 720p
Built-in Devices Speaker, 0.59-inch TFT LCD
Brightness (White) 3400 lumens
Brightness (Colour) 3400 lumens
Contrast Ratio 16000:1 (dynamic)
Resolution WXGA (1280 x 800)
Native Aspect Ratio 16:10
Colour Support 1.07 billion colours
Bulb type 215 Watt
Bulb life cycle Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input RGB, S-Video, composite video, component video LAN
Speakers Speaker(s) - integrated
Environmental Standards TCO Certified Projectors 2
Power AC 120/230 V (50 - 60 Hz)
Power Consumption Operational 298 Watt
Dimensions (WxDxH) 34.4 cm x 31.5 cm x 9.4 cm
Weight 3.9 kg
Resources
The following resources are available for the Epson EB-536wi Short Throw Interactive WXGA 3400 Lumens Projector
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson EB-536wi Short T...
£1,194.92
