Epson EB-675W 3200 Lumens WXGA UST Ultra Short Throw Project
Product codes
HD-ready classroom projector With a large scalable screen size of up to 100 inches to display HD-ready WXGA content, this innovative teaching solution enhances learning. Featuring HD-ready WXGA resolution and a brightness of 3,200 lumens, the EB-675W's ultra-short-throw design allows you to present large images from a very short distance with minimised shadows and glare. A 14,000:1 contrast ratio and HDMI input mean that students benefit from sharp, clear images. High-quality, bright images Epson’s 3LCD technology ensures high-quality images with equally high White and Colour Light Output for vivid colours and bright images, even in daylight, and three times brighter colours than competitive projectors. Enhanced learning Split-screen functionality allows two pieces of content to be displayed simultaneously without compromising on quality. The moderator function allows teachers to remain in control, choosing what content to display. Document camera compatibility Connecting the optional Epson document camera allows you to easily display images and 3D objects with incredible detail for the whole class to see. Keep costs down Project for longer with improved reliability and a longer lamp life of up to 10,000 hours in eco mode. Optional wireless capability Wirelessly display content easily from a range of smart devices and Google Chromebooks using our iProjection App
Product Description Epson EB-675W - 3LCD projector - LAN
Device Type 3LCD projector - 720p
Colour Grey, white
Built-in Devices Speaker
Brightness (White) 3200 lumens
Brightness (Colour) 3200 lumens
Contrast Ratio 300:1 / 14000:1 (dynamic)
Resolution WXGA (1280 x 800)
Native Aspect Ratio 16:10
Colour Support 1.07 billion colours
Bulb type 215 Watt
Bulb life cycle Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input RGB, composite video LAN
Speakers Speaker(s) - integrated
Power AC 230V (50 - 60 Hz)
Power Consumption Operational 311 Watt
Dimensions (WxDxH) 36.7 cm x 40 cm x 14.9 cm
Weight 5.7 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson EB-675W 3200 Lum...
