General |
Device Type |
3LCD projector - 720p |
Built-in Devices |
Speaker |
Networking |
Ethernet |
Enclosure Colour |
Grey, white |
Projector |
Brightness (White) |
3500 lumens |
Brightness (Colour) |
3500 lumens |
Brightness (Reduced) |
2900 lumens |
Contrast Ratio |
300:1 / 14000:1 (dynamic) |
Image Size |
152 cm - 254 cm |
Projection Distance |
0.4 m - 0.6 m |
Throw Ratio |
0.28:1 |
Digital Zoom Factor |
1.35x |
Resolution |
WXGA - WXGA (1280 x 800) |
Native Aspect Ratio |
16:10 |
Colour Support |
1.07 billion colours |
Bulb type |
250 Watt |
Features |
sRGB colour profile, Blackboard Mode, EPSON 3LCD technology, Whiteboard Mode, Automatic Brightness Adjustment, Dynamic Lamp Control, Dynamic Mode, Theater Mode |
Lens |
Focus Type |
Manual |
Lens Aperture |
F/1.6 |
Keystone Correction Direction |
Horizontal, vertical |
Vertical Keystone Correction |
-3 / +3 |
Horizontal Keystone Correction |
-3 / +3 |
Video Input |
Analogue video Signal |
RGB, composite video |
Video Interfaces |
VGA, HDMI, composite video, MHL |
LAN and Wireless Image Transferring Protocols |
Wired LAN |
Speakers |
Type |
Integrated |
Sound Output Mode |
Mono |
Output Power / Channel |
16 Watt |
Speakers |
1 x mixed channel |
Expansion / Connectivity |
Interfaces |
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x Mobile High-Definition Link (MHL) / HDMI , 2 x HDMI input - 19 pin HDMI Type A , 1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 3 x audio line-in - mini-phone stereo 3.5 mm , 1 x microphone , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) |
Miscellaneous |
Included Accessories |
Wireless remote control |
Cables Included |
1 x USB cable |
Mounting Kit |
Included |
Security Features |
Security lock slot (cable lock sold separately), password protection |
Environmental Standards |
TCO Certified |
TCO Certified Projectors 2 |
Power |
Power Source |
AC |
Nominal Voltage |
AC 230V (50 - 60 Hz) |
Power Consumption Operational |
354 Watt |
Power Consumption Stand by |
0.39 Watt |
Software / System Requirements |
Software Included |
EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection |
Dimensions & Weight |
Width |
36.7 cm |
Depth |
40 cm |
Height |
14.9 cm |
Weight |
5.7 kg |
Manufacturer Warranty |
Service & Support |
Limited warranty - 3 years / 8000 hours - on-site , Limited warranty - lamp - 1 year / 1000 hours |
Environmental Parameters |
Min Operating Temperature |
5 °C |
Max Operating Temperature |
35 °C |
Humidity Range Operating |
20 - 80% |
Sound Emission |
35 dBA |
Sound Emission (Economic Mode) |
30 dBA |
