Epson EB-695Wi 3500 Lumens WXGA UST Projector
£2,397.26
14 in stock
Delivery:
Standard: 1-3 working days
  • Portability: Non-portable
  • Stock Status: In Stock
Product codes
With a brightness of 3,500 lumens and HD-readyWXGA resolution, the EB-695Wi's ultra-short-throw design allows you to present large images from a very short distance with minimised shadows and glare. This projector offers ultimate interactivity by combining finger-touch with dual pen capability. A 14,000:1 contrast ratio and HDMI input mean that students benefit from sharp, clear images.
High brightness and image quality
Epson’s 3LCD technology ensures high-quality images with equally high White and Colour Light Output for vivid colours and bright images, even in daylight, and three times brighter colours than leading competitive projectors1. With a scalable display size of up to 100 inches, two types of content can be displayed using the split-screen without compromising on quality.
Finger-touch and dual pen
Use your fingers to annotate directly onto the screen. Epson's interactive pens are now even more responsive and easy to use. With the new dual pens, teacher and student or two students can work simultaneously using different attributes
Highly reliable
Project for longer with improved reliability and a longer lamp life of up to 10,000 hours in eco mode.
Interact and enhance learning
Multi-PC projection software allows teachers and students to share content simultaneously. The moderator function allows teachers to remain in control, choosing what content to display. Combine two projectors to create one large interactive display. Split-screen capability allows teachers to display two separate types of content simultaneously, such as a lesson plan from a PC and a still image or video clip from a document camera.
Optional wireless capability
Wirelessly display content easily from a range of smart devices and Google Chromebooks using our iProjection App**
Projection System 3LCD Technology
LCD Panel 0.59 inch with D9
Colour Light Output 3,500 Lumen- 2,900 Lumen (economy) In accordance with IDMS15.4
White Light Output 3,500 Lumen - 2,900 Lumen (economy) In accordance with ISO 21118:2012
Resolution WXGA, 1280 x 800, 16:10
High Definition HD ready
Aspect Ratio 16:10
Contrast Ratio 14,000 : 1
Lamp 250 W, 5,000 h durability, 10,000 h durability (economy mode), 9,000 h durability (economy mode
Keystone Correction Manual vertical: ± 3 °, Manual horizontal ± 3 °
Colour Processing 10 Bits
2D Vertical Refresh Rate 100 Hz - 120 Hz
Colour Reproduction Upto 1.07 billion colours
Projection Ratio 0.28 - 0.37:1
Zoom Digital, Factor: 1 - 1.35
Lens Optical
Image Size 60 inches - 100 inches
Projection Distance Wide 0.4 m ( 60 inch screen)
Projection Distance Tele 0.6 m ( 100 inch screen)
Projection Lens F Number 1.6
Focal Distance 3.7 mm
Focus Manual
Offset 5.8 : 1
USB Display Function USB 2.0 Type A, USB 2.0 Type B, RS-232C, Wired Network, Wireless LAN IEEE 802.11b/g/n (optional), VGA in (2x), VGA out, HDMI in (3x), Composite in, RGB in (2x), RGB out, MHL, Stereo mini jack audio out, Stereo mini jack audio in (3x), Microphone input, Sync. in, Sync. out
Epson iProjection App Ad-Hoc / Infrastructure
2D Colour Modes Dynamic, Cinema, Presentation, sRGB, Blackboard
Interactivity Yes - pen and finger-touch
Video Colour Modes Blackboard, Cinema, Dynamic, Presentation, sRGB
Projector control via: AMX, Crestron, Control4
Energy Use 354 Watt, 309 Watt (economy), 0.37 Watt (standby)
Supply Voltage AC 220 V - 240 V, 50 Hz - 60 Hz
Product dimensions 367? x 400 x 149 mm (Width x Depth x Height)
Product weight 5.8 kg
Noise Level Normal: 35 dB (A) - Economy: 30 dB (A) - Eco2: 29 dB (A)
Temperature Operation 5° C - 40° C, Storage -10° C - 60° C
Humidity Operation 20% - 80%, Storage 10% - 90%
Included Software Easy Interactive Tools, EasyMP Network Monitor, EasyMP Multi PC Projection
Options Air filter, Connection and control box, Document camera, External Speaker, Pen tip(Felt), Pen tip(Teflon), Wireless LAN unit
Compatible Operating Systems Linux, Mac OS 10.10.x, Mac OS 10.7.x, Mac OS 10.8.x, Mac OS 10.9.x, Windows 10, Windows 8, Windows 8.1
Loudspeaker 16 Watt
What's in the box CD Manual, Finger touch unit, Interactive pens, Main unit, Pen tray, Power cable, Quick Start Guide, Remote control incl. batteries, SMART Notebook software entitlement booklet, USB cable, User Manual (CD-ROM), Wall hanging bracket, Warranty card
Colour White / Grey
Warranty 36 months On-site service or 8,000 h, Lamp: 12 months or 1,000 h
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson EB-695Wi 3500 Lu...
£2,397.26
