Epson EB-696Ui 3800 Lumens WUXGA Ultra Short Throw Projector
£2,940.79
Delivery:
Standard: 1-3 working days
  • Type: WXGA projector
  • Brightness: 3800ANSI lumens
  • Contrast Ratio: 16000: 1
  • Portability: Non-portable
  • Stock Status: In Stock
Product codes
This new projector offers ultimate interactivity by combining finger-touch with dual pen capability. With a brightness level of 3,800 lumens and FullHD WUXGA resolution, the EB-696Ui's ultra-short-throw design allows you to present large images from a very short distance with minimised shadows and glare. A 16,000:1 contrast ratio and HDMI input means that students benefit from sharp, clear images.
Quality image
Epson’s 3LCD technology ensures high-quality images with equally high White and Colour Light Output for vivid colours and bright images, even in daylight, and three times brighter colours than leading competitive projectors1. With a scalable display size of up to 100 inches, two types of content can be displayed using the split-screen without compromising on quality.
Finger-touch and dual pen
Use your fingers to annotate directly onto the screen. Epson's interactive pens are now even more responsive and easy to use. With the new dual pens, teacher and student or two students can work simultaneously using different attributes.
Reliable
Project for longer with improved reliability and a longer lamp life of up to 10,000 hours in eco mode.
Save time
Simply plug in and turn on – there's no warm-up time and the PC-free annotation mode means that teachers don't even need to power up their computers. The interactive function does not require drivers to be installed and it auto-calibrates.
Interact and enhance learning
Multi-PC projection software allows teachers and students to share content simultaneously. The moderator function allows teachers to remain in control, choosing what content to display. Combine two projectors to create one large interactive display.
Product Description Epson EB-696Ui - 3LCD projector - LAN
Device Type 3LCD projector - 1080p
Colour Grey, white
Built-in Devices Speaker
Brightness (White) 3800 lumens
Brightness (Colour) 3800 lumens
Contrast Ratio 300:1 / 16000:1 (dynamic)
Resolution WUXGA (1920 x 1200)
Native Aspect Ratio 16:10
Colour Support 1.07 billion colours
Bulb type 267 Watt
Bulb life cycle Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input RGB, S-Video LAN
Speakers Speaker(s) - integrated
Environmental Standards TCO Certified Projectors 2
Power AC 230V (50 - 60 Hz)
Power Consumption Operational 401 Watt
Dimensions (WxDxH) 47.4 cm x 44.7 cm x 13 cm
Weight 8.3 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson EB-696Ui 3800 Lu...
£2,940.79
