Epson EB-980W WXGA 3LCD 3800 Lumens Projector
£764.40
Delivery:
Key features
  • WXGA projector offering 3,800 lumens and 15,000:1 contrast ratio
  • 10 years' worth of lessons before maintenance is required
  • IProjection app, split-screen function, moderator function
  • Portability: Non-portable
Product codes
Excellent visibility for every student
With this WXGA projector ,content will be bright, vivid and clear, ensuring that everyone can engage with the lesson. Providing excellent visibility, this projector is scalable up to 300 inches and is bright even in high ambient lighting conditions. It's all thanks to the high 3,800-lumen output and 15,000:1 contrast ratio.
Minimal maintenance
When resources are limited, our reliable projectors and long-lasting lamps help to eliminate downtime and unnecessary service costs. Imagine what you could achieve with minimal interruptions - our projectors help to make that a reality with up to 10 years' worth of lessons before a replacement lamp is required or the air filter needs attention .
Easy set up
Every classroom is different so you need a projector that is simple to set up and position. With our wide 1.6x optical zoom and vertical/horizontal keystone correction, it's easy to get up and running quickly.
Utilise multiple devices
Capture your students' attention and nurture a collaborative environment with hassle-free connectivity solutions. With the iProjection app, it's easy to display content from PCs and smart devices . The split-screen function can be utilised to show content from multiple devices simultaneously, while the moderator function lets you review content before it is displayed.
Product Description Epson EB-980W - 3LCD projector - LAN
Device Type 3LCD projector - 720p
Colour Grey, white
Built-in Devices Speaker
Brightness (White) 3800 lumens
Brightness (Colour) 3800 lumens
Contrast Ratio 15000:1 (dynamic)
Resolution WXGA (1280 x 800)
Native Aspect Ratio 16:10
Colour Support 1.07 billion colours
Bulb type UHE 210 Watt
Bulb life cycle Up to 6000 hour(s) - normal mode , Up to 12000 hour(s) - economic mode
Video Input RGB, S-Video, composite video LAN
Speakers Speaker(s) - integrated
Environmental Standards TCO Certified Projectors 2
Power AC 120/230 V (50 - 60 Hz)
Power Consumption Operational 309 Watt
Dimensions (WxDxH) 30.9 cm x 29.3 cm x 10.5 cm
Weight 3.1 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson EB-980W WXGA 3LC...
£764.40
