Epson EB-G7900U-WUXGA 7000 ANSI Lumens Installation
£4,012.42
12 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 3LCD technology; superior white balance; better colour matching
  • Exceptional sharpness, clarity and detail for the real 4K effect
  • True flexibility without distortion or loss of brightness
  • Stores projector settings such as image position, focus and zoom
  • Switch mode without having to change the lamp
  • Portability: Non-portable
  • Stock Status: In Stock
Product codes
Superior image quality
Ensure superb quality and the best possible delivery of presentations with this powerful installation projector for large venues. Featuring Epson's own 3LCD technology and equally high White and Colour Light Output, WUXGA resolution images are vivid and bright, even in daylight with its 7,000 lumens brightness. For a next-level viewing experience, the projector features 4K enhancement, giving images exceptional sharpness, clarity and detail.
Easy positioning
Thanks to a new range of motorised lenses, including optional ultra-short throw (UST) lens, and both vertical and horizontal lens shift, the projector benefits from true 360° installation flexibility allowing it to be placed almost anywhere.
Quick set-up
Get started quickly thanks to a lens memory function, which stores projector settings such as image position, focus and zoom, for prompt access when projecting images in different aspect ratios, or using different lenses. Split-screen allows dual feeds to be projected, while a portrait projection mode is possible without changing the lamp. For integration with a wide range of systems, inputs include HDMI, HDBaseT, DVI-D and component video.
Product Description Epson EB-G7900U - 3LCD projector - LAN
Device Type 3LCD projector - 1080p
Built-in Devices Speaker
Brightness (White) 7000 lumens
Brightness (Colour) 7000 lumens
Contrast Ratio 2000:1 / 50000:1 (dynamic)
Resolution WUXGA (1920 x 1200)
Native Aspect Ratio 16:10
Colour Support 1.07 billion colours
Lens Shift Direction Horizontal, vertical
Bulb type 400 Watt
Bulb life cycle Up to 2000 hours - normal mode , Up to 4000 hours - economic mode
Video Input RGB, component video LAN
Speakers Speaker(s) - integrated
Power AC 120/230 V (50/60 Hz)
Power Consumption Operational 572 Watt
Dimensions (WxDxH) 52.5 cm x 47.2 cm x 18.9 cm
Weight 12.7 kg
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson EB-G7900U-WUXGA...
£4,012.42
