Epson EB-X39 XGA 1024 x 768 3500 Lumens 3LCD Projector
£452.13
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 3LCD technology and equally high white and colour light output
  • Small and light enough to be carried an used across several rooms
  • Network-enabled and Wi-Fi capable (optional accessory required)
  • Lamp and filter life of 12,000 hours in eco mode
  • Project from many sources with HDMI and optional Wi-Fi connectivity
  • Type: LCD projector
  • Brightness: 3500ANSI lumens
  • Portability: Portable
  • Resolution: 1024x768
  • Stock Status: In Stock
Product codes
With the control of a host PC, up to 50 terminals can be connected via the multi-PC projection from a single projector. The host PC acts as a moderator, selecting media from up to four terminals to be projected simultaneously. With the moderator function, you can maintain control and prevent tampering with what's projected on screen.
Enjoy enhanced connectivity and flexibility with Wi-Fi connectivity. Easily share and transmit images, text and files from your smart devices using the "Epson iProjection" application for smooth and smart projections. And with an additional attachment piece holding the wireless LAN adaptor in place, your transmissions will never be interrupted.
Product Description Epson EB-X39 - 3LCD projector - portable - LAN
Device Type 3LCD projector
Colour White grey
Built-in Devices Speaker
Brightness (White) 3500 lumens
Brightness (Colour) 3500 lumens
Contrast Ratio 15000:1 (dynamic)
Resolution XGA (1024 x 768)
Native Aspect Ratio 4:3
Colour Support 1.07 billion colours
Bulb type UHE 210 Watt
Bulb life cycle Up to 6000 hour(s) - normal mode , Up to 12000 hour(s) - economic mode
Video Input RGB, composite video LAN
Speakers Speaker(s) - integrated
Power AC 120/230 V (50/60 Hz)
Power Consumption Operational 309 Watt
Dimensions (WxDxH) 30.2 cm x 24.9 cm x 9.2 cm
Weight 2.7 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson EB-X39 XGA 1024...
£452.13
