Epson EcoTank ET-4500 Multifunction 4-in-1 Colour Inkjet Printer
£348.48
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Equivalent of 88 cartridges worth of ink included
  • Print up to 4,500 pages in black and 7,500 pages in colour
  • Easy-refill ink tank system
  • Print from mobile devices
  • Print, copy, scan & fax
  • Type: Fax / copier / printer / scanner
  • Functionality: Copier, Fax, Printer, Scanner
  • Technology: Ink-jet
  • Max Paper Size: A4 (210 x 297 mm), Legal (216 x 356 mm)
  • Stock Status: In Stock
Product codes
Say goodbye to ink cartridges
The star of the ET-4500 is its newly designed integrated ultra-high-capacity ink tank system, which completely does away with the need for ink cartridges. That means less fuss and much more printing between refills than other inkjet printers.
Two years of ink
Imagine not having to think about ink for two years. As well as doing away with ink cartridges, the ET-4500 has four colour 70ml Epson genuine ink bottles in the box, which make it easy, clean and quick to fill the ink tanks.
Ultra-low cost
The ET-4500 saves you 70% in printing costs on average. It achieves an ultra-low cost per page, printing up to 4,000 pages in black and 6,500 pages in colour at just a fraction of a penny per page4.
Wi-Fi and Ethernet connectivity
Equipped with Wi-Fi and Wi-Fi direct, the ET-4500 can take advantage of all Epson Connect5 features. Print quickly and easily over Wi-Fi from a smartphone using the free Epson iPrint app, print remotely or email the ET-4500 a print job.
Quick, quality results
The ET-4500 uses Epson's own Micro Piezo technology for excellent-quality print-outs. Mono prints are delivered at a rate of 9.2 pages per minute while it can issue 4.5 colour pages per minute. A 30-page ADF helps boost productivity.
Product Description Epson EcoTank ET-4500 - multifunction printer - colour
Device Type Multifunction printer
Fax Type Super G3
Printing Technology Ink-jet (colour)
Inkjet Technology Epson Micro Piezo - 4-ink
Max Printing Speed Up to 33 ppm (mono) / up to 15 ppm (colour)
Max Printing Resolution Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Max Fax Transmission Speed 33.6 Kbps
Scanning 1200 x 2400 dpi
Original Type Sheets
Document Feeder Capacity 30 sheets
Media Size Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type Envelopes, plain paper, photo paper
Standard Media Capacity 100 sheets
Connection Availability Yes
Interface USB, LAN, Wi-Fi
AirPrint Enabled Yes
Power AC 120/230 V
Dimensions (WxDxH) 49 cm x 37.7 cm x 22.9 cm
Weight 6.3 kg
Microsoft Certification Compatible with Windows 7
Environmental Standards ENERGY STAR Qualified
Accessories
Ink
Other bundles
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson EcoTank ET-4500...
£348.48
