Epson EcoTank ET-4550 Multifunction 4-in-1 Colour Inkjet Printer
Key features
  • With enough ink to print 11,000 pages
  • Save 70% on printing costs
  • Double-sided printing
  • Print from mobile devices
  • Print, copy, scan & fax
Product codes
Say goodbye to ink cartridges
The star of the ET-4550 is its newly designed integrated ultra-high-capacity ink tank system, which completely does away with the need for ink cartridges. That means less fuss and much more printing between refills than other inkjet printers. As well as doing away with ink cartridges, the ET-4550 has six 70ml colour and two 140ml black Epson genuine ink bottles in the box, which are easy, clean and quick to use.
Ultra-low cost
The ET-4550 saves you 70% on printing costs on average. Included in the box are two full sets of ink which will enable you to print up to 11,000 pages in black and colour , at just a fraction of a penny per page . In fact, a customer would need to buy 72 ink cartridges on average to get the same yields .
Wi-Fi and Ethernet connectivity
Equipped with Wi-Fi and Wi-Fi direct, the ET-4550 can take advantage of all Epson Connect4 features. Print quickly and easily over Wi-Fi from a smartphone using the free Epson iPrint app, print remotely or email the ET-4550 a print job.
Quick, quality results
The ET-4550 uses Epson's own Micro Piezo technology for excellent-quality print-outs. Mono prints are delivered at a rate of 13 pages per minute while it can issue 7.3 colour pages per minute5. The 150-sheet paper tray, 30-page ADF and automatic duplex printing help you boost productivity, while black pigment ink is used to deliver high-quality text printing.
Product Description Epson EcoTank ET-4550 - multifunction printer - colour
Device Type Multifunction printer
Fax Type Super G3
Printing Technology Ink-jet (colour)
Inkjet Technology Epson Micro Piezo - 4-ink
Max Printing Speed Up to 33 ppm (mono) / up to 20 ppm (colour)
Max Printing Resolution Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed 33.6 Kbps
Scanning 1200 x 2400 dpi
Original Type Sheets
Document Feeder Capacity 30 sheets
Media Size Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type Envelopes, plain paper, photo paper
Standard Media Capacity 150 sheets
Automatic Duplexing Yes (printing)
Connection Availability Yes
Interface USB, LAN, Wi-Fi(n)
AirPrint Enabled Yes
Power AC 120/230 V
Dimensions (WxDxH) 51.5 cm x 36 cm x 24.1 cm
Weight 7.4 kg
Microsoft Certification Compatible with Windows 7
Environmental Standards ENERGY STAR Qualified
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson EcoTank ET-4550...
