Sophisticated and sleek design
You'll want to leave this projector out on display with its on-trend metallic finish, elegantly rounded corners and minimal buttons.
Supersized content wherever you want
Create an impressive 150-inch display wherever you want with this light and compact projector. It's easy to pick up and move from room-to-room or out of the house. It can also be turned on its side and project in any direction - on a wall, ceiling or floor.
Bright and colourful
Even in normal daylight this projector can deliver a bright and vibrant picture, so there's no need to turn lights off, block windows or even use a screen. It's thanks to the laser light source and 3LCD technology.
Stress-free set up
Launch the welcome guide with the remote to see how to easy it is to set up. Sound is taken care of with the built-in speakers and headphone jack, or connect to sound bars via Bluetooth.
Find and view whatever you like
Show content from a phone, tablet, DVD player, games console or laptop by inserting a cable into the HDMI port. Streaming content is simple too as devices (such as Amazon Fire TV, Google Chromecast, Roku) can be plugged in the back.
Watch your favourite content for the next 10 years
Thanks to this projector's long-lasting laser light source, you'll be able to watch your favourite content for the next 10 years without maintenance.
Product Description | Epson EF-100W - 3LCD projector - portable - Bluetooth | Device Type | 3LCD projector - 720p | Colour | White | Built-in Devices | Speaker | Contrast Ratio | 2500000:1 (dynamic) | Native Aspect Ratio | 16:10 | Colour Support | 1.07 billion colours | Bulb type | Laser | Video Input | Bluetooth | Speakers | Speaker(s) - integrated | Power | AC 120/230 V (50 - 60 Hz) | Power Consumption Operational | 172 Watt | Dimensions (WxDxH) | 21 cm x 23 cm x 9.2 cm | Weight | 2.7 kg | Manufacturer Warranty | 5-year warranty |
General | |
Networking | Bluetooth |
Enclosure Colour | White |
Projector | |
Image Size | 76.2 cm - 381 cm |
Throw Ratio | 1.04 - 1.4:1 |
Digital Zoom Factor | 1.35x |
Max Sync Rate (V x H) | 120 Hz |
Bulb type | Laser |
Features | EPSON Quick Corner, Crystal Clear Fine (C2 Fine), Dynamic Mode, instant on/off, Bright Cinema, Cinema Mode, RGB liquid crystal shutter |
Lens | |
Focus Type | Manual |
Lens Aperture | F/1.58 |
Keystone Correction Direction | Horizontal, vertical |
Vertical Keystone Correction | -45 / +45 |
Horizontal Keystone Correction | -40 / +40 |
Video Input | |
Video Interfaces | HDMI |
LAN and Wireless Image Transferring Protocols | Bluetooth |
Speakers | |
Type | Integrated |
Sound Output Mode | Mono |
Output Power / Channel | 5 Watt |
Speakers | 1 x mixed channel |
Expansion / Connectivity | |
Interfaces | 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x HDMI input - 19 pin HDMI Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 - 4 pin USB Type A |
Miscellaneous | |
Included Accessories | Wireless remote control |
Security Features | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Power | |
Power Source | AC |
Nominal Voltage | AC 120/230 V (50 - 60 Hz) |
Power Consumption Stand by | 0.4 Watt |
Dimensions & Weight | |
Width | 21 cm |
Depth | 23 cm |
Height | 9.2 cm |
Weight | 2.7 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years / 12000 hours - on-site |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% |
Sound Emission | 29 dBA |
Sound Emission (Economic Mode) | 26 dBA |
