Bring the movie theater experience home with this HDR-capable, 4K-enhanced projector, utilizing Epson's technology and 3LCD technology.
Product Description | Epson EH-TW7400 - LCD projector - 3D - LAN | Device Type | LCD projector - 1080p | 3D Capable | Yes (3D glasses sold separately) | Colour | White | Brightness (White) | 2400 lumens | Brightness (Colour) | 2400 lumens | Contrast Ratio | 200000:1 (dynamic) | Resolution | Full HD (1920 x 1080) | Native Aspect Ratio | 16:9 | Colour Support | 1.07 billion colours | Lens Shift Direction | Horizontal, vertical | Bulb type | UHE 250 Watt | Bulb life cycle | Up to 3500 hour(s) - normal mode , Up to 5000 hour(s) - economic mode | Video Input | RGB LAN | Power | AC 120/230 V (50/60 Hz) | Power Consumption Operational | 355 Watt | Dimensions (WxDxH) | 52 cm x 45 cm x 19.3 cm | Weight | 11.2 kg | Manufacturer Warranty | 2-year warranty |
General | |
Networking | Ethernet |
Enclosure Colour | White |
Projector | |
Image Size | 127 cm - 762 cm |
Projection Distance | 3 m - 6.3 m |
Throw Ratio | 1.35 - 2.84:1 |
Resolution | Full HD - Full HD (1920 x 1080) |
Max Sync Rate (V x H) | 480 Hz |
Features | Side-by-Side, Dynamic Mode, 4K Enhancement, Bright Cinema, Cinema Mode, 3D Dynamic Mode, 3D Cinema Mode, 3D depth adjustment |
Lens | |
Focus Type | Powered |
Lens Aperture | F/2.0-3.0 |
Zoom Type | Powered |
Zoom Factor | 2.1x |
Keystone Correction Direction | Vertical |
Vertical Keystone Correction | -30 / +30 |
Vertical Lens Shift | 96.3% / 96.3% |
Horizontal Lens Shift | 47.1% / 47.1% |
Video Input | |
Analogue video Signal | RGB |
Video Interfaces | VGA, HDMI |
LAN and Wireless Image Transferring Protocols | Wired LAN |
Expansion / Connectivity | |
Interfaces | 1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B (management) , 3 x HDMI - 19 pin HDMI Type A , 1 x network - RJ-45 , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) |
Miscellaneous | |
Included Accessories | Remote control, HDMI cable clamp |
Security Features | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Power | |
Power Source | AC |
Nominal Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption Stand by | 0.2 Watt |
Dimensions & Weight | |
Width | 52 cm |
Depth | 45 cm |
Height | 19.3 cm |
Weight | 11.2 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years - carry-in , Limited warranty - lamp - 3 years / 3000 hours |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Sound Emission | 31 dBA |
Sound Emission (Economic Mode) | 20 dBA |
