Epson ELPSC26 Projector Screen 80" Multi-Aspect 4:3
£186.40
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Highly flexible with adjustable aspect ratios
  • Easy to set-up and compact carrying size
  • Light screen with perfect size to fit retail shelves
  • The perfect screen for retailers: one reference compatible with all projectors on the market
  • Accessory Type: Projection screen
  • Stock Status: In Stock
Product codes
The Epson multi-aspect screen offers you all-in-one screen solution, which fits all projectors. Thanks to its flexible set-up feature, you can easily adjust the screen to 4:3, 16:9 or 16:10 aspect ratios within seconds. Its exceptional value is complemented by its compact size and portable weight, offering you extra flexibility. The Epson multi-aspect screen is definitely your preferred partner for business or home projection.
Product Description Epson 65"/74"/80" Multi-aspect - projection screen - 80" (203.2 cm)
Product Type Projection screen
Projection Screen Image Diagonal Size 80" (203.2 cm)
Aspect Ratio 16:10 / 16:9 / 4:3
Weight 10 kg
Designed For Epson EB-1750, 1751, 1760, 1761, 1770, 1771, 1775, 1776, 1840, 1860, 1900, 1920, 1925, 945, 955, 965, 98, S02, S03, S04, S10, S17, S18, S27, S31, S92, U04, U32, W03, W04, W110, W18, W28, W29, W31, W32, X03, X10, X11, X15, X18, X24, X27, X31, x92, EH-TW550
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson ELPSC26 Projecto...
£186.40
