Epson Epson Short Throw Projector Wall Mount - ELPMB45 - ST EB52
£155.40
Delivery:
Key features
  • Flexible installation - wall mounting plate allows for easy installation using one or two wall studs
  • Easily adjustable - telescopic extension arm supports a throw distance from 27 to 47 inches
  • Ideal for virtually any image size - for projecting 16:10 content from 68 to 113 inches (PowerLite 525W or 535W), or 4:3 content from 63 to 106 inches (PowerLite 520 or 530)
  • Easy image alignment - vertical and horizontal shift adjustments, plus pitch, roll and swivel adjustments
Product codes
Designed exclusively for use with Epson's PowerLite 520, 525W, 530, 535W and BrightLink 536Wi short-throw projectors, this wall mount offers an easy, affordable solution for integration with a variety of interactive or standard dry erase whiteboards. The wide mounting plate and telescopic extension arm offer convenient and flexible installation, while the vertical and horizontal adjustments provide easy image alignment. And, when your short-throw projector is attached to the wall mount, there is less shadow interference and glare, which ensures a more optimal presenting and viewing experience.
Epson ELPMB45 - wall mount
Wall mount
Recommended Use
Projector
Epson EB-520, EB-525W, EB-530, EB-530 S, EB-535W, EB-536WI; PowerLite 520, 525W, 530, 535W
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson Epson Short Thro...
£155.40
