Epson Expression Premium XP-830 - Multifunction Colour Printer
£123.58
Delivery:
Key features
  • Print, scan, copy and fax
  • Freedom to print and scan from anywhere
  • Multiple users can print and scan easily
  • One for A4 and another for photo paper
  • Clear navigation and PC-free printing from a memory card
Product codes
Best of both worlds
Create outstanding glossy photos and crisp, clear text documents with the new five-colour Claria Premium dye and pigment ink-set. Photographs will be crystal clear with vibrant colours and deep, rich blacks thanks to the addition of a Photo Black ink cartridge.
Mobile printing
Whether using a smartphone or tablet, the iPrint app can be downloaded to a range of devices for truly wireless printing and scanning. The possibilities don't end there, with Epson Email Print , it is possible to print from anywhere in the world by simply emailing documents and photos directly to the printer. For creative-minded people the Creative Print app can access Facebook photos, create custom greeting cards and stationery, and even turn photos into colouring book templates. For added versatility, Wi-Fi Direct allows easy printing from compatible wireless devices without the need for a network connection.
Easy to use
A 10.9cm interactive LCD touch-screen makes navigation and printing directly from memory card quick and simple. For even easier operation, a motorised control panel and output tray mean hassle-free printing.
Advanced control
Easily switch between photo and A4-sized prints with two front-loading paper trays. Print onto thicker media using the rear speciality media feed and enjoy fast and easy double-sided copying, scanning and faxing with the ADF. You can also directly print onto suitable CDs/DVDs.
Epson Expression Premium XP-830 - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson Micro Piezo - 5-ink
Max Printing Speed
Up to 32 ppm (mono) / up to 32 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
4800 x 4800 dpi
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
30 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
120 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from memory card, save to memory card, print from USB flash drive, save to USB flash drive, scan to e-mail, scan to Cloud
AC 230 V (50/60Hz)
39 cm x 33.9 cm x 19.1 cm
8.2 kg
Microsoft Certification
Compatible with Windows 7
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson Expression Premi...
£123.58
