Epson FX-2190 Dot Matrix Printer
Key features
  • Class-leading speed - up to 680cps
  • Compact, robust and reliable
  • Long-lasting ribbon
  • Flexible paper handling from front, top, rear and bottom
  • Handles media up to 136 columns wide
  • Two optional cut sheet feeders to store different forms
Product codes
This wide carriage printer combines high speed printing with outstanding reliability.
A mean volume between failure of 52 million lines makes this printer suitable for medium and large print volumes. The paper can be fed from the front, top, rear or bottom and an optional additional push/pull tractor unit can store a second continuous form, which is ideal for commercial and industrial environments.
Also available as network version FX-2190N.
Product Description Epson FX 2190 - printer - monochrome - dot-matrix
Printer Type Workgroup printer - dot-matrix - 9 pin - monochrome
Weight 9.4 kg
Localisation United Kingdom
Media Size Class A3
Max Media Size A3 (297 x 420 mm)
Print Speed Up to 680 char/sec - max speed , Up to 566 char/sec - max speed , Up to 627 char/sec - fast draft , Up to 559 char/sec - fast draft , Up to 503 char/sec - draft , Up to 419 char/sec - draft , Up to 125.9 char/sec - letter , Up to 104.6 char/sec - letter
Interface Parallel, USB
RAM Installed (Max) 128 KB
Barcodes Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Code 128, Interleaved 2 of 5, Postnet
Power AC 230V
System Requirements Microsoft Windows 95/98, Microsoft Windows 2000 / NT4.0, Microsoft Windows Millennium Edition, Microsoft Windows XP
Microsoft Certification Works with Windows Vista
Manufacturer Warranty 1 year warranty
Dimensions (WxDxH) 58.9 cm x 35 cm x 16.8 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson FX-2190 Dot Matr...
