Epson FX 2190N Mono Dot-Matrix Printer
Key features
  • Class-leading speed - up to 680cps
  • Compact, robust and reliable
  • Long-lasting ribbon
  • Handles 1 original + 5 copies
  • Flexible paper handling from front, top, rear and bottom
  • Handles media up to 136 columns wide
  • Two optional cut sheet feeders to store different forms
  • Second push tractor option to accommodate two continuous forms
  • Standard Parallel and USB interfaces
  • Optional wireless (Not available in all countries) and wired network interfaces
Product codes
Documents
This wide carriage printer combines high speed printing with outstanding reliability.
A mean volume between failure of 52 million lines makes this printer suitable for medium and large print volumes. The paper can be fed from the front, top, rear or bottom and an optional additional push/pull tractor unit can store a second continuous form, which is ideal for commercial and industrial environments.
Epson FX 2190N - printer - monochrome - dot-matrix
Printer Type
Workgroup printer - dot-matrix - 9 pin - monochrome
9.4 kg
Max Media Size
364 x 420 mm, continuous paper 102 mm - 406 mm (width)
Max Media Size (Custom)
420 mm x 364 mm
Print Speed
Up to 680 char/sec - max speed , Up to 566 char/sec - max speed , Up to 559 char/sec - fast draft , Up to 627 char/sec - fast draft , Up to 419 char/sec - draft , Up to 503 char/sec - draft , Up to 104.6 char/sec - near letter , Up to 125.9 char/sec - near letter
Parallel, USB, LAN
RAM Installed (Max)
128 KB
Language Simulation
EPSON ESC/P, IBM PPDS
Barcodes
Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Code 128, Interleaved 2 of 5, Postnet
Media Type
Envelopes, labels, plain paper, continuous forms
Monthly Duty Cycle (max)
23000 pages
Print server - Ethernet, Fast Ethernet - plug-in module
AC 230V
Microsoft Certification
Works with Windows Vista
1 year warranty
58.9 cm x 35 cm x 16.8 cm
Resources
The following resources are available for the Epson FX 2190N Mono Dot-Matrix Printer
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson FX 2190N Mono Do...
