"Reliability and speed. This 24-pin wide carriage printer takes care of big print jobs without a fuss. You can rely on high quality results on a wide range of paper types while the impressive 576 cps (at 12 cpi) print speed is perfect for large volume tasks. This robust device is very dependable and has a print head life of 400 million strokes per wire, plus a meant time between failure of 20,000 power-on hours.
Flexibility. Choice of front, top, bottom and rear paper paths gives you even more control over desk space management. And the addition of a USB interface means more flexibility in connectivity.
Longer ribbon life. With a ribbon life of around 15 million characters, the ribbon replacement cycles are longer, which brings down running costs and maintenance time."
Product Description | Epson LQ 2190 - printer - monochrome - dot-matrix | Printer Type | Workgroup printer - dot-matrix - 24 pin - monochrome | Weight | 13 kg | Media Size Class | A3 | Max Media Size | A3 (297 x 420 mm) | Print Speed | Up to 480 char/sec - fast draft , Up to 576 char/sec - fast draft , Up to 360 char/sec - draft , Up to 432 char/sec - draft , Up to 120 char/sec - laser quality , Up to 144 char/sec - laser quality | Max Resolution (B&W) | 10 cpi | Interface | Parallel, USB | RAM Installed (Max) | 128 KB | Language Simulation | EPSON ESC/P 2, IBM PPDS | Media Type | Envelopes, labels, plain paper, continuous forms, cards | Power | AC 240 V | System Requirements | Microsoft Windows 2000/XP/Vista/7 | Microsoft Certification | Compatible with Windows 7 | Manufacturer Warranty | 1-year warranty | Dimensions (WxDxH) | 63.9 cm x 40.2 cm x 25.6 cm |
General | |
Printer | |
Print Speed | Up to 480 char/sec - fast draft - 10 cpi , Up to 576 char/sec - fast draft - 12 cpi , Up to 360 char/sec - draft - 10 cpi , Up to 432 char/sec - draft - 12 cpi , Up to 120 char/sec - laser quality - 10 cpi , Up to 144 char/sec - laser quality - 12 cpi |
Connectivity Technology | Wired |
Fonts Included | 10 x bitmapped , 4 x scalable , 8 x barcode |
RAM | |
Media Handling | |
Media Sizes | A3 (297 x 420 mm) |
Media Feeders | 1 x manual |
Max Sheets in Multi-Part Form | 6 |
Expansion / Connectivity | |
Connections | 1 x parallel - 36 PIN Centronics , 1 x USB - 4 pin USB Type B |
Miscellaneous | |
MTBF | 20,000 hour(s) |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Power | |
Power Device | Power supply - internal |
Voltage Required | AC 240 V |
Power Consumption Operational | 46 Watt |
Power Consumption Stand by / Sleep | 3 Watt |
Software / System Requirements | |
Software Included | Drivers & Utilities |
OS Required | Microsoft Windows 2000/XP/Vista/7 |
Environmental Standards | |
ENERGY STAR | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - carry-in |
Environmental Parameters | |
Sound Emission (Operating) | 54 dB |
Dimensions & Weight | |
Width | 63.9 cm |
Depth | 40.2 cm |
Height | 25.6 cm |
Weight | 13 kg |
