Epson LQ 2190 Mono Dot-Matrix Printer
£1,103.96
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Fast, reliable printing
  • Enjoy 24-pin quality up to A3 size and 576 cps
  • Multi-part flexibility
  • Print up to 6-part forms (1 original + 5 copies)
  • Paper handling
  • Choose from front, top, bottom, rear paper paths
  • Print Speed Enhancer
  • For faster printing of bit images under Windows environment
  • Easy connectivity
  • Parallel and USB interfaces as standard
  • Type: Printer
  • Functionality: Printer
  • Output Type: Monochrome
  • Wireless Capability: Wired
  • Technology: Dot-matrix
Product codes
"Reliability and speed. This 24-pin wide carriage printer takes care of big print jobs without a fuss. You can rely on high quality results on a wide range of paper types while the impressive 576 cps (at 12 cpi) print speed is perfect for large volume tasks. This robust device is very dependable and has a print head life of 400 million strokes per wire, plus a meant time between failure of 20,000 power-on hours.
Flexibility. Choice of front, top, bottom and rear paper paths gives you even more control over desk space management. And the addition of a USB interface means more flexibility in connectivity.
Longer ribbon life. With a ribbon life of around 15 million characters, the ribbon replacement cycles are longer, which brings down running costs and maintenance time."
Product Description Epson LQ 2190 - printer - monochrome - dot-matrix
Printer Type Workgroup printer - dot-matrix - 24 pin - monochrome
Weight 13 kg
Media Size Class A3
Max Media Size A3 (297 x 420 mm)
Print Speed Up to 480 char/sec - fast draft , Up to 576 char/sec - fast draft , Up to 360 char/sec - draft , Up to 432 char/sec - draft , Up to 120 char/sec - laser quality , Up to 144 char/sec - laser quality
Max Resolution (B&W) 10 cpi
Interface Parallel, USB
RAM Installed (Max) 128 KB
Language Simulation EPSON ESC/P 2, IBM PPDS
Media Type Envelopes, labels, plain paper, continuous forms, cards
Power AC 240 V
System Requirements Microsoft Windows 2000/XP/Vista/7
Microsoft Certification Compatible with Windows 7
Manufacturer Warranty 1-year warranty
Dimensions (WxDxH) 63.9 cm x 40.2 cm x 25.6 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson LQ 2190 Mono Dot...
£1,103.96
