Epson LQ 590 Mono Dot-Matrix Printer
Key features
  • Work fast with printing up to 529 cps
  • Built to last and deliver in any environment
  • Choose from top, bottom, front and rear feeds
  • Range includes 2 cut-sheet feeders, tractor unit
  • Comprehensive desktop and network connectivity
Product codes
Reliable performance:
This printer is built to last, with a mean volume between failure of 40 million lines, a mean 'time between failure' of 20,000 power-on hours and a print head life of 400 million strokes per wire. The ribbon matches up to the other hardware, with a life of up to 5 million characters.
Take your pick:
Choose the way you work with a range of cut-sheet or continuous paper handling combinations that suits the demands of any office or warehouse.
Fits right in:
Get set up quickly with standard USB and parallel and optional serial, Twinax and Coax interfaces. Expand access with optional wired networking.
Epson LQ 590 - printer - monochrome - dot-matrix
Printer Type
Workgroup printer - dot-matrix - 24 pin - monochrome
7.1 kg
Max Media Size
254 x 559 mm, JIS B4 (257 x 364 mm), continuous paper 101.6 mm - 254 mm (width)
Max Media Size (Custom)
257 mm x 364 mm
Print Speed
Up to 440 char/sec - fast draft , Up to 529 char/sec - fast draft , Up to 330 char/sec - draft , Up to 396 char/sec - draft , Up to 495 char/sec - draft , Up to 110 char/sec - letter , Up to 132 char/sec - letter , Up to 165 char/sec - letter
Parallel, USB
RAM Installed (Max)
128 KB
Barcodes
Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Code 128, Interleaved 2 of 5, Postnet
Media Type
Envelopes, plain paper, continuous forms
AC 230V
Microsoft Windows 95/98/ME/NT/2000/XP
Microsoft Certification
Works with Windows Vista
1 year warranty
43.7 cm x 37.5 cm x 17.1 cm
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson LQ 590 Mono Dot-...
