Epson LQ 630 Dot Matrix Network Printer
Key features
  • Fast print speed up to 360 cps
  • Compact and robust design
  • Handles up to 1 original plus 3 copies
  • Flatbed technology for ergonomic front paper feed
Product codes
LQ-630 is a small and reliable printer especially for counter application. With its small design with 80 columns, LQ-630 fits perfectly in environments where space is rather limited. The ejection of both, continuous paper and cut sheets at front side enables easy handling of the print outs only at the front side of the printer. Due to the printer's flatbed technology, LQ-630 can print even smallest cut sheet forms and stickers down to 9 cm x 7 cm. LQ-630 can ideally be used with retail stores, banks, post offices, doctors' surgeries, ticket shops, cinemas, pizza services. Moreover the printer is perfect for label and protocol printing with trade industrial firms.
Product Description Epson LQ 630 - printer - monochrome - dot-matrix
Printer Type Workgroup printer - dot-matrix - 24 pin - monochrome
Weight 3.5 kg
Max Media Size JIS B4 (257 x 364 mm), continuous paper 101.6 mm - 254 mm (width)
Print Speed Up to 300 char/sec - fast draft , Up to 360 char/sec - fast draft , Up to 225 char/sec - draft , Up to 79 char/sec - best
Max Resolution (B&W) 360 x 180 dpi
Interface Parallel, USB 2.0
RAM Installed (Max) 32 KB
Language Simulation EPSON ESC/P 2, IBM PPDS
Media Type Labels, plain paper, continuous forms
System Requirements Microsoft Windows 98, Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows 7, Windows 8
Manufacturer Warranty 1-year warranty
Dimensions (WxDxH) 38.6 cm x 30.6 cm x 18.5 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson LQ 630 Dot Matri...
