Epson LQ 690 Mono Dot-Matrix Printer
£600.10
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • The 106 column capacity with 24 pins means greater quality
  • Impressive print speed of 529 cps
  • Big memory buffer of 128 KB and built-in Print Speed Enhancer ensures faster printing of bit image data
  • Combined power of print head life and MTBF of 20,000 hours
  • Low power consumption so better for environment
  • Type: Printer
  • Functionality: Printer
  • Output Type: Monochrome
  • Wireless Capability: Wired
  • Technology: Dot-matrix
Product codes
Very fast:
Print faster and more productively, thanks to the Print Speed Enhancer - a unique feature in the Epson driver. Perfect for those printing directly from any Windows applications. – Also, LQ-690 is capable of printing an impressive 529 cps (12 cpi) when using printer resident fonts.
High ribbon yield:
In a demanding and fast-moving work environment, a high ribbon yield is essential, and with 10 million characters per ribbon, this marks out the LQ-690 as a leading force in the flatbed market. It is also cost-effective with long ribbon replacement cycles, low running costs and total cost of ownership.
Dependable:
Durable and built to last, users will be assured by the MTBF (mean time between failures) of 20,000 power on hours, plus a print head life of 400 million strokes/wire. This results in greater productivity and less maintenance - essential when producing large amounts of documents and data.
Smart design:
This compact hard-working printer is designed to fit on your desk. The platen gap adjustment lever is thoughtfully hidden under the front cover, to avoid accidental setting changes and paper setting is made easy thanks to the ruler in the front paper guide.
Product Description Epson LQ 690 - printer - monochrome - dot-matrix
Printer Type Workgroup printer - dot-matrix - 24 pin - monochrome
Weight 6.8 kg
Print Speed Up to 440 char/sec - fast draft , Up to 330 char/sec - draft , Up to 110 char/sec - letter , Up to 529 char/sec - fast draft , Up to 396 char/sec - draft , Up to 132 char/sec - letter
Max Resolution (B&W) 12 cpi
Interface Parallel, USB
RAM Installed (Max) 128 KB
Language Simulation EPSON ESC/P 2, IBM PPDS
Barcodes Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Code 128, Interleaved 2 of 5, Postnet
Media Type Envelopes, labels, plain paper, continuous forms
Printer Features Print Speed Enhancer
Power AC 230V
Microsoft Certification Compatible with Windows 7
Dimensions (WxDxH) 48 cm x 37 cm x 21 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson LQ 690 Mono Dot-...
£600.10
