Epson LQ350 Dot Matrix Printer
£248.10
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • MTBF of 10,000 operating hours
  • Parallel, Serial and USB interfaces
  • Fits neatly onto desks
  • Type: Printer
  • Functionality: Printer
  • Output Type: Monochrome
  • Wireless Capability: Wired
  • Technology: Dot-matrix
Product codes
A very economical printer to run, the LQ-350 helps save money with its high ribbon yield of 2.5 million characters and its low power consumption. Using just 1.3W in sleep mode and 23W when powered on, the LQ-350 is qualified by ENERGY STAR for its excellent energy efficiency.
Easy to integrate, the LQ-350 has Parallel, Serial and USB interfaces as standard, and will fit neatly onto desks thanks to its compact design and cable management system.
Product Description Epson LQ 350 - printer - monochrome - dot-matrix
Printer Type Personal printer - dot-matrix - 24 pin - monochrome
Weight 4.1 kg
Print Speed Up to 347 char/sec - max speed , Up to 260 char/sec - draft , Up to 86 char/sec - laser quality
Interface Parallel, USB 2.0, USB host
RAM Installed (Max) 128 KB integrated
Language Simulation EPSON ESC/P 2, IBM 2390 Plus
Media Type Envelopes, labels, plain paper, continuous forms
Power AC 230V
System Requirements Microsoft Windows 98, Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
Dimensions (WxDxH) 34.8 cm x 27.5 cm x 15.4 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Epson LQ350 Dot Matrix...
£248.10
